Since (at least newer releases) of vanilla OpenWrt do not use Mediatek’s wappd, current Turris OS is fine as well, I assume?
from what I can understand, the vulnerability is in any Mediatek wifi driver compiled using specific versions of Mediatek SDK (version 7.4.0.1 and before for MT7915). If Turris developers has used last versions of OpenWrt open source driver to build the firmware, we are safe. If they’ve used the Mediatek driver with SDK version 7.4.0.1 or before, we are not safe. Is there any developer who can confirm Turris routers don’t use Mediatek proprietary wifi drivers ?
source (CVE-2024-20017) https://corp.mediatek.com/product-security-bulletin/March-2024
Thank you in advance
confirming, that we are using same package as OpenWrt upstream.
Best regards,
Tom
