Hello
Here is my flow ( made with ascii flow)
WWW
┌───▼──────┐ vlan-iot ┌──────┐
│ Firewall ├──────────────────►Player│
│local-wan 11.0.1.2
┌────▼──┐ lan┌───────┐
│ Omnia ├──────┤Station│
192.168.2.2 192.168.1.2
My player publish a airplay service, which is received on Firewall.
Firewall
- run avahi-daemon with
enable-reflector=yes
Omnia
umdns
is disabled -
avahi-daemon
is installed and running withenable-reflector=yes
. it get airplay services from Firewall but on one condition.
I just discover if foris-controller
is running and none of my services are available for the Station.
Once stopped everything appears.
I saw in /etc/init.d/foris-controller
an option : --zeroconf-enabled
but when i remove it i lost reforis access.
So i can’t stop it and can’t edit edit otherwise i loose reforis
access
I don’t know where to dig to get more infos
I didn’t find anything relevant elsewhere. only this issue ( with a MR) Foris-controller won't fully start when something is running on port 5353 (#200) · Issues · Turris / Foris Controller / foris-controller · GitLab
