Hallo Folks,
I have installed the opkg package "mcproxy"
When starting the Programm binary it
works fine! The autostart/init Script does simply nothing. enable/start/restart nothing. Also no failures in /var/log/messages
Can anyone confirm this ?
Thanks a lot
Alex
The config is a little bit tricky:
So i did a fresh install:
okpg install mcproxy
rm -f /etc/config/mcproxy
touch /etc/config/mcproxy
uci set mcproxy.mcproxy="mcproxy"
uci set mcproxy.mcproxy.respawn="1"
uci set mcproxy.mcproxy.protocol="IGMPv3"
uci set mcproxy.satip="instance"
uci set mcproxy.satip.name="satip"
uci add_list mcproxy.satip.upstream=„eth0.20“
uci add_list mcproxy.satip.downstream=„br-lan“
uci commit mcproxy
/etc/mcproxy.conf
protocol IGMPv3;
pinstance satip: „br-lan“ ==> „eth0.20“;
/etc/init.d/mcproxy enable
/etc/init.d/mcproxy start
I´m happy its working now!!
