root@turris:~# opkg update
Downloading https://repo.turris.cz/hbs/omnia/packages/core/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_core
Downloading https://repo.turris.cz/hbs/omnia/packages/core/Packages.sig
Signature check passed.
Downloading https://repo.turris.cz/hbs/omnia/packages/base/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_base
Downloading https://repo.turris.cz/hbs/omnia/packages/base/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/cesnet/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_cesnet
Downloading https://repo.turris.cz/hbs/omnia/packages/cesnet/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_luci
Downloading https://repo.turris.cz/hbs/omnia/packages/luci/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/node/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_node
Downloading https://repo.turris.cz/hbs/omnia/packages/node/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/openwisp/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_openwisp
Downloading https://repo.turris.cz/hbs/omnia/packages/openwisp/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_packages
Downloading https://repo.turris.cz/hbs/omnia/packages/packages/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_routing
Downloading https://repo.turris.cz/hbs/omnia/packages/routing/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/sidn/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_sidn
Downloading https://repo.turris.cz/hbs/omnia/packages/sidn/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_telephony
Downloading https://repo.turris.cz/hbs/omnia/packages/telephony/Packages.sig
Downloading https://repo.turris.cz/hbs/omnia/packages/turrispackages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_turrispackages
Downloading https://repo.turris.cz/hbs/omnia/packages/turrispackages/Packages.sig
root@turris:~# opkg find usbreset
usbreset - 5 - This package contains the small usbreset utility which
can be used to send a USB port reset to a USB device -
useful for debugging or to force re-detection of particular
devices.
root@turris:~#
Looks like you’re not missing anything. The question is - why was I missing it? I ran opkg update so many times today. Heck, I can see in my terminal history that usbreset wasn’t present two opkg update runs ago. But well, I rerun it. And usbreset shows up now.
And here’s the ultimate reason why it wasn’t showing up. You have to execute opkg update after each reboot. Otherwise, only installed packages will show on opkg list. Not those available in the repos.
OpenWrt recompiles the packages regularly, so you really want need fresh package lists…
Doing this after each reboot just wears down the flash without giving you necessarily uptodate usable lists when you finally want to use them, well unless yoy reboot daily
Why should it wear down flash? Package list cash should somewhere go to ramdisk, right?
But you are right, one would want fresh lists for the moment you need them.
