Is it possible to do a manual upgrade to v5.0 on the Omnia using the link here?
https://repo.turris.cz/hbs/medkit/omnia-medkit-latest.tar.gz.
Many Thanks!
Many Thanks!
Why shouldn’t it work? If you are not sure, you might want to take a look at our documentation, there is described method how you can do re-flash on your router and don’t forget to compare checksums.
Sorry, perhaps I should revise my question…
Has the link been updated so that when downloaded, v5.0 is the version being pulled down for install?
Yes, it is done automatically.
