Hi all,
I am trying to run a LXC container on my Turris router. I have had this running in the past with no problem, but now I can’t get it working.
My configuration of the container is pretty basic. Please see below.
# For additional config options, please look at lxc.container.conf(5)
# Uncomment the following line to support nesting containers:
lxc.include = /usr/share/lxc/config/nesting.conf
# (Be aware this has security implications)
# # Some workarounds
# Template to generate fixed MAC address
# Distribution configuration
lxc.arch = armv7l
# Container specific configuration
lxc.include = /usr/share/lxc/config/common.conf
lxc.hook.start-host = /usr/share/lxc/hooks/systemd-workaround
lxc.rootfs.path = btrfs:/srv/lxc/ubuntu-lxc/rootfs
lxc.uts.name = ubuntu-lxc
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = br-lab
lxc.net.0.flags = up
lxc.net.0.name = eth0
lxc.net.0.hwaddr = d2:71:cf:e6:67:c0
#lxc.net.0.ipv4.address = 192.168.1.30/24
#lxc.net.0.ipv4.gateway = 192.168.1.1
Basically, when I enable DHCP on the interface where the veth is supposed to be bridged, the container will start and get an IP address from the DHCP server. However, shortly after the interface just gets disabled. I don’t know why that is happening.
Nov 29 10:07:32 turris dnsmasq-dhcp[4467]: DHCPDISCOVER(br-lab) d2:71:cf:e6:67:c0
Nov 29 10:07:32 turris dnsmasq-dhcp[4467]: DHCPOFFER(br-lab) 192.168.1.243 d2:71:cf:e6:67:c0
Nov 29 10:07:32 turris dnsmasq-dhcp[4467]: DHCPREQUEST(br-lab) 192.168.1.243 d2:71:cf:e6:67:c0
Nov 29 10:07:32 turris dnsmasq-dhcp[4467]: DHCPACK(br-lab) 192.168.1.243 d2:71:cf:e6:67:c0 ubuntu-lxc
Nov 29 09:07:33 turris dhcp_host_domain_ng.py: DHCP add new hostname [ubuntu-lxc,192.168.1.243]
Nov 29 09:07:33 turris dhcp_host_domain_ng.py: Refresh kresd leases
Nov 29 10:07:42 turris kernel: [48142.090058] br-lab: port 3(vethirXRFU) entered disabled state
[48126.674218] eth0: renamed from vethpXubjD
[48126.740006] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[48126.740127] IPv6: ADDRCONF(NETDEV_CHANGE): vethirXRFU: link becomes ready
[48126.740219] br-lab: port 3(vethirXRFU) entered blocking state
[48126.740231] br-lab: port 3(vethirXRFU) entered forwarding state
The same behavior when I let the DHCP server enabled but assign a static IP in the configuration of the container.
If I disabled the DHCP server, I can assign a static IP via the configuration and the interface does NOT get disabled. This is unfortunately not an option, because then I have no DNS resolution.
It seems I can’t set the DNS server from the LXC configuration, nor can I create the resolv.conf. The container seems to be using systemd-resolved to automatically generate the resolv.conf when it gets a DHCP lease.
Does anyone have any suggestions to either fix the interface issue or set the DNS server statically?
Many thanks.
Kind regards,
Martin
