LXC Container - no templates
i try to setup some LXC Container but there isnt any templates i can choose from.
Afair there where templates a couple of versions back.
Can smb help?
Thanks for your help. The folder “/srv/lxc” was missing and got created but it did not work out:
root@turris:/srv/lxc# lxc-create -t download -n debian
Setting up the GPG keyring
ERROR: Unable to fetch GPG key from keyserver.
lxc-create: lxccontainer.c: create_run_template: 1201 container creation template for debian failed
lxc-create: lxc_create.c: main: 274 Error creating container debian
The template list in web interface is still empty.
Whatever it was its working again with 3.8.3 update
Same with me.
Turris 1.0
root@turris:~# lxc-create -t download -n pokus
Downloading the image index
DIST    RELEASE ARCH    VARIANT BUILD
Turris_OS       stable  armv7l  default 2017-09-25
Turris_OS       stable  ppc     default 2017-09-25
Alpine  3.4     armv7l  default 2017-09-25
ArchLinux       latest  armv7l  default 2017-09-25
Debian  Stretch armv7l  default 2017-09-25
Debian  Buster  armv7l  default 2017-09-25
Gentoo  stable  armv7l  default 2017-09-25
openSUSE        42.2    armv7l  default 2017-09-25
openSUSE        42.3    armv7l  default 2017-09-25
openSUSE        Tumbleweed      armv7l  default 2017-09-25
Sabayon current armv7l  default 2017-09-25
Ubuntu  Xenial  armv7l  default 2017-09-25
Ubuntu  Zesty   armv7l  default 2017-09-25
Ubuntu  Artful  armv7l  default 2017-09-25
Distribution: Turrsi_OS
Release: stable
Architecture: ppc
ERROR: Couldn't find a matching image.
lxc-create: lxccontainer.c: create_run_template: 1201 container creation template for pokus failed
lxc-create: lxc_create.c: main: 274 Error creating container pokus
Same issue here with same error message. Is there any update on what isn’t working or has someone found a workaround?
please can you be more specific, which problem do you have?
We know that you can’t install LXC containers via LuCI. I already confirmed it here and we’re working on it.
Right now as workaround you can install LXC containers via SSH (except Ubuntu Zesty, openSUSE Tumbleweed and 42.2; we’re looking on them, why somebody can’t install them) and then you can start/restart and even stop them via LuCI.
Turris 1.0 with Turris_OS / Stable / ppc still a problem.
Thanks for the info. I actually related to @commar 's comment where he/I fail to create a new container via SSH. Here my console output for completeness:
# lxc-create -t download -n test
Turris_OS	stable	armv7l	default	2018-01-07
Turris_OS	stable	ppc	default	2018-01-07
Alpine	3.4	armv7l	default	2018-01-07
ArchLinux	latest	armv7l	default	2018-01-07
Debian	Stretch	armv7l	default	2018-01-07
Debian	Buster	armv7l	default	2018-01-07
Gentoo	stable	armv7l	default	2018-01-07
openSUSE	42.2	armv7l	default	2018-01-07
openSUSE	42.3	armv7l	default	2018-01-07
openSUSE	Tumbleweed	armv7l	default	2018-01-07
Sabayon	current	armv7l	default	2018-01-07
Ubuntu	Xenial	armv7l	default	2018-01-07
Ubuntu	Zesty	armv7l	default	2018-01-07
Ubuntu	Artful	armv7l	default	2018-01-07
Distribution: Debian
Release: Stretch
Architecture: armv71
lxc-create: lxccontainer.c: create_run_template: 1201 container creation template for test failed
lxc-create: lxc_create.c: main: 274 Error creating container test
Firmware Version:
OpenWrt omnia 15.05 r47055 / LuCI 49c3edd5861fd032fa8379ceda525c27a908a114 branch (git-17.212.24321-49c3edd)
Kernel Version:
4.4.106-1e4a549d177ab3da12b2052fba6a4dd5-3
I see mistake in your output.
It’s armv7l (not 1)
//EDIT: @commar You’re right. I tried it, too and it doesn’t work. I told it to miska and he’ll look at it.
This is embarrassing, I should have seen that myself. It indeed did the trick. Thank you very much!
Can anyone work out my typo? I am trying to execute the following command, but it come back with a syntax error:
lxc-create -n test -t download -d Turris_OS -r stable -a armv7l
However, this works fine if I just execute:
and then enter the distribution, release & architecture manually.
Fixed! Now you can install Turris OS on PPC platform! :slight_smile:
@Pepe is there any plans to add debian stretch to Turris 1 LXC repo ? We are on kernel 4 already so that should be possible.
I started my Omnia Turris some days ago and graded up to the latest software version.
I have the same problem - I can not see the list of images and a lxc-create fails:
lxc-create -t download -n foo
lxc-create: lxccontainer.c: create_run_template: 1201 container creation template for foo failed
lxc-create: lxc_create.c: main: 274 Error creating container foo
This is with the latest stable version:
cat /etc/turris-version
3.10.8
uname -a
Linux FooTurris 4.4.161-0a333a8e606ab056173befac424900d2-1 #1 SMP Mon Oct 15 08:42:55 CEST 2018 armv7l n
Any ideas?
I just updated to Medkit - latest (4-something) and have the same issue:
root@turris:~# lxc-create -n test -t download
lxc-create: test: lxccontainer.c: create_run_template: 1617 Failed to create container from template
lxc-create: test: tools/lxc_create.c: main: 327 Failed to create container test
Also interesting: It tries to connect via http despite ssl is enabled in config:
root@turris:~# lxc-create -n test -t download – --no-validate
ERROR: Failed to download http://repo.turris.cz/lxc//meta/1.0/index-system
Same for me, unfortunatelly :frowning:
This helped:
