Pi-hole works. However the LXC container does not automatically start on router reboot. The container name is Pihole and I can start it manually using lxc-start -n Pihole
These are the entire contents of /etc/config/lxc-auto
config container
option name Pihole
option timeout 60
are not script files, therefore they cannot be executed. They only contain the configuration that I linked in the first post.
However, you were correct to look in luci startup in http://192.168.1.1/cgi-bin/luci/admin/system/startup, it had lxc-auto disabled. This is not covered in any of the documentation.
Edit:
Alternatively, running these commands works too (which is what you probably meant).
#config container
#option name container1
# How long to give container to shutdown gracefully before killing it
# Default 300s
#option timeout 30
# Commnads to run before starting container
#list command '/bin/command --option'
config container
option name Pihole
option timeout 60
#lxc-start -P /mnt/sda1 -n Pihole
I am having similar setup like @JardaB , while i am using option delay_start 10 for my lxc with pihole and for others i have it set to 30. When i was having all without delay sometimes services within lxc container were having issues when trying to comunicate outside the container (znc, ngircd, eggdrop ).
Also i had issue with assigned IP (i’ve put wanted ip/mac in lxc config),but somehow it also gets ip from dhcp range. Once i created static lease, it worked fine (only one and wanted IP was used by pihole container).
