LXC container and attach USB devices
I’m trying to attach a mini PCIe 3G modem to a LXC container, but that doesn’t seem to work.
Device is listed on Turris as ttyUSBx:
root@turris:~# ls -l /dev/ttyUSB*
crw-r–r-- 1 root root 188, 0 Jun 24 11:36 /dev/ttyUSB0
crw-r–r-- 1 root root 188, 1 Jun 24 11:36 /dev/ttyUSB1
crw-r–r-- 1 root root 188, 2 Jun 24 11:36 /dev/ttyUSB2
crw-r–r-- 1 root root 188, 3 Jun 24 11:36 /dev/ttyUSB3
crw-r–r-- 1 root root 188, 4 Jun 24 11:36 /dev/ttyUSB4
I added the following config in LXC container:
# Device mapping
lxc.cgroup.devices.allow = c 188:* rwm
lxc.mount.entry = /dev/ttyUSB0 dev/ttyUSB0 none bind,optional
lxc.mount.entry = /dev/ttyUSB1 dev/ttyUSB1 none bind,optional
lxc.mount.entry = /dev/ttyUSB3 dev/ttyUSB2 none bind,optional
lxc.mount.entry = /dev/ttyUSB3 dev/ttyUSB3 none bind,optional
lxc.mount.entry = /dev/ttyUSB4 dev/ttyUSB4 none bind,optional
But no sign of ttyUSBx in container:
root@LXC_NAME:~# ls -l /dev/ttyUSB*
ls: cannot access /dev/ttyUSB*: No such file or directory
Any idea?
Thanks!
About to do something similar. Hooking up a RFLink home automation gateway to a Home Assistant running on Debian/python3. Home Assistant is up and running (literally a 5-minute job!) and now I need the USB working. Was wondering how to route physical ports to container.
I’ll be reading along :slight_smile:
Let’s try this.
Put this row to your’s config for this LXC container and then dont forget to restart it.
lxc.mount.entry = /dev/bus/usb dev/bus/usb none bind,optional,create=dir
and I think it would be good to remove this:
If it doesn’t work I can try it in 1-2 days. I have laying around some 2G USB modem and it should be almost same. :slight_smile:
OT:
For DVB tuners I use this (on Turris 1.x):
lxc.group.devices.allow = c 212:* rwm
lxc.mount.entry = /dev/dvb dev/dvb none bind,optional,create=dir
lxc.mount.entry = /dev/bus/usb/001 dev/bus/usb/001 none bind,optional,create=dir
and wrote article, which you can find in wiki :slight_smile: There will be more. I think for modem it should be almost same
So I got curious; went and plugged the gateway into the Turris (backside USB).
The gateway is an Arduino Mega/2560 (CH340) with a radio frontend stuck to it. On the Turris i get the following response:
2017-06-24T19:52:08+02:00 info kernel: [165073.384676] usb 4-1: new full-speed USB device number 3 using xhci-hcd
2017-06-24T17:53:01+02:00 info /usr/sbin/cron[30567]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-06-24T17:54:01+02:00 info /usr/sbin/cron[31057]: (root) CMD (nethist_stats.lua)
Compare this to the output I got on my Debian-laptop:
Jun 24 19:55:05 flattop kernel: [1040967.273004] usb 1-2.2: new full-speed USB device number 6 using xhci_hcd
Jun 24 19:55:05 flattop kernel: [1040967.374160] usb 1-2.2: New USB device found, idVendor=1a86, idProduct=7523
Jun 24 19:55:05 flattop kernel: [1040967.374175] usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jun 24 19:55:05 flattop kernel: [1040967.374184] usb 1-2.2: Product: USB2.0-Serial
Jun 24 19:55:05 flattop mtp-probe: checking bus 1, device 6: “/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2”
Jun 24 19:55:05 flattop mtp-probe: bus: 1, device: 6 was not an MTP device
Jun 24 19:55:05 flattop kernel: [1040967.505756] usbcore: registered new interface driver usbserial
Jun 24 19:55:05 flattop kernel: [1040967.507108] usbcore: registered new interface driver usbserial_generic
Jun 24 19:55:05 flattop kernel: [1040967.508278] usbserial: USB Serial support registered for generic
Jun 24 19:55:05 flattop kernel: [1040967.509661] usbcore: registered new interface driver ch341
Jun 24 19:55:05 flattop kernel: [1040967.509694] usbserial: USB Serial support registered for ch341-uart
Jun 24 19:55:05 flattop kernel: [1040967.509723] ch341 1-2.2:1.0: ch341-uart converter detected
Jun 24 19:55:05 flattop kernel: [1040967.510904] usb 1-2.2: ch341-uart converter now attached to ttyUSB0
Jun 24 19:55:06 flattop org.freedesktop.FileManager1[1510]: org.kde.baloo: “/org/kde/solid/udev/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2:1.0/ttyUSB0/tty/ttyUSB0”
A somewhat more verbose output, eh?
To me it looks like Turris doesn’t recognize the CH340 serial-to-USB chip as being that. My Debian laptop does and instantiates a /dev/ttyUSB0 representing it.
If Turris doesn’t recognize the device, it won’t be possible to ‘forward’ it to my LXC container I guess.
So how does one get Turris to recognize an Arduino Mega?
That’s correct.
I think you will need to install appropriate module if it is available on repo:
Omnia: Index of /omnia/packages/
Turris 1.x: Index of /turris/packages/
If it not available:
a) you will need compile kernel yourself
b) you can ask for adding driver in kernel by default via email ? :slight_smile:
c) compile module yourself and then modprobe it to kernel (if it is possible to OpenWRT. Honestly I dont know)
Ooh… I’m a little bit out of my comfort zone here. Still, I see that there’s a kmod-usb-serial-ch341 package available for the Omnia.
Would I simply go and install it using ‘ipkg’ and job done? I sense there must be more needed - an usb-handling-functionality…
Hi, command to install on TO should be like this:
opkg update opkg install kmod-usb-serial kmod-usb-serial-ch341
Done. Amazing how simple it is. Turris response is now:
2017-06-24T21:10:57+02:00 info kernel: [169801.695127] usb 4-1: new full-speed USB device number 4 using xhci-hcd
2017-06-24T21:10:57+02:00 info kernel: [169801.836874] ch341 4-1:1.0: ch341-uart converter detected
2017-06-24T21:10:57+02:00 info kernel: [169801.837714] usb 4-1: ch341-uart converter now attached to ttyUSB0
Next step is to get the device to turn up in the container :slight_smile:
Much obliged for swift assistance :slight_smile:
So, with LXC container config:
Device mapping (https://forum.test.turris.cz/t/lxc-container-and-attach-usb-devices/4412)
I get the following output from ls -l on client when a device is present on host (ttyUSB0):
root@idefix:/home/buggerall# cd /dev
root@idefix:/dev# ls -l
total 0
crw–w---- 1 root tty 136, 0 Jun 24 19:19 console
lrwxrwxrwx 1 root root 13 Jun 24 19:19 fd → /proc/self/fd
crw-rw-rw- 1 root root 1, 7 Jun 24 19:19 full
lrwxrwxrwx 1 root root 25 Jun 24 19:19 initctl → /run/systemd/initctl/fifo
lrwxrwxrwx 1 root root 28 Jun 24 19:19 log → /run/systemd/journal/dev-log
drwxrwxrwt 2 root root 40 Jun 24 19:19 mqueue
crw-rw-rw- 1 root root 1, 3 Jun 24 19:19 null
lrwxrwxrwx 1 root root 13 Jun 24 19:19 ptmx → /dev/pts/ptmx
drwxr-xr-x 2 root root 0 Jun 24 19:19 pts
crw-rw-rw- 1 root root 1, 8 Jun 24 19:19 random
drwxrwxrwt 2 root root 40 Jun 24 19:19 shm
lrwxrwxrwx 1 root root 15 Jun 24 19:19 stderr → /proc/self/fd/2
lrwxrwxrwx 1 root root 15 Jun 24 19:19 stdin → /proc/self/fd/0
lrwxrwxrwx 1 root root 15 Jun 24 19:19 stdout → /proc/self/fd/1
crw-rw-rw- 1 root root 5, 0 Jun 24 19:19 tty
crw–w---- 1 root tty 136, 0 Jun 24 19:19 tty1
crw–w---- 1 root tty 136, 1 Jun 24 19:19 tty2
crw–w---- 1 root tty 136, 2 Jun 24 19:19 tty3
crw–w---- 1 root tty 136, 3 Jun 24 19:19 tty4
crw-rw-rw- 1 root root 1, 9 Jun 24 19:19 urandom
crw-rw-rw- 1 root root 1, 5 Jun 24 19:19 zero
root@idefix:/dev#
No cigar. Any ideas?
Same result here. Btw thanks to all of you for your support :slight_smile:
Cant link any USB as well, but I am 600km away from home so cannot do full experiments.
I would say that thislxc.mount.entry = /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=dir lxc.mount.entry = /dev/ttyUSB1 dev/ttyUSB1 none bind,optional,create=dir lxc.mount.entry = /dev/ttyUSB3 dev/ttyUSB2 none bind,optional,create=dir lxc.mount.entry = /dev/ttyUSB3 dev/ttyUSB3 none bind,optional,create=dir lxc.mount.entry = /dev/ttyUSB4 dev/ttyUSB4 none bind,optional,create=dir
have to stay in config, its similiar to this lxc.mount.entry = /dev/dvb dev/dvb none bind,optional,create=dir
for the tuner.
Being 600km away, you’re excused for not being able to do experiments :slight_smile:
I’ve tried fiddling with lxc.mount.entry, but that got me nowhere.
Then I’ve tried reading about the configuration file content here:
https://linuxcontainers.org/lxc/manpages//man5/lxc.container.conf.5.html
In the /DEV DIRECTORY section I stumbled on the lxc.autodev option and tried it out. Bad idea. Turris lxc falls flat on its face trying to execute it, bringing the GUI to a standstill in the process.
Had to go into my container directory and manually remove autodev from conf to get the GUI going again. You have been warned.
Would this be a task to point the Turris devteam’s attention to? I mean - making hardware accessible from inside a container has potential use to everyone doing these little automation tasks for which the Turris is so well suited.
@Weafyr, once you come home I’d like to hear more on what you can learn from experiments. In your own time :slight_smile:
Yup, good idea. How could I open a enhancement request?
Cheers,
No idea. Write so the official support email, referencing this thread?
We can hope the devs are reading along…
Anyways; we as users must remain aware of the fact that lxc machines are not number crunchers. They are aimed at lightweight tasks.
Again, a Home Assistant would - in my view - be just that. A lightweight task, handling input from hardware doing the heavy lifting and presenting an automation interface. But that’ll require beforementioned interface-transfer to be operational.
this worked for me:
https://klein-gedruckt.de/2016/12/turris-omnia-arduino-nano-usb/
including hotplug etc…
Hello all,
I am trying to run RFXTRX433E connected to Omnia and run OpenHAB in LXC container, here is what I have:
I have installed kmod-usb-serial-ftdi, result is that Omnia see the RFXTRX433E device:
[322483.927384] ftdi_sio 4-1:1.0: FTDI USB Serial Device converter detected
[322483.927624] usb 4-1: FTDI USB Serial Device converter now attached to ttyUSB0
If type lsusb I can see:
root@turris:/dev# lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I have this setup in lxc config:
lxc.mount.entry = /dev/bus/usb dev/bus/usb none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file 0 0
in LXC container I can see almost the same
root@LXC_NAME:/dev# lsusb
And also in /dev I can see ttyUSB0
root@LXC_NAME:/dev# ls -la ttyU*
crw-r–r-- 0 root root 188, 0 Mar 2 23:30 ttyUSB0
but OpenHAB is not able to communicate with RFXTRX433E device at all.
Any ideas?
Honza K.
I use a similar USB device with HomeAssistant, which in running in an LXC container.
Before I offer any help, can I check that OpenHAB runs in an LXC container?
For those who do want to use a USB z-wave controller on a TO, be aware that it’s devicename can change during reboots. I use the following hotplug script (on the TO) to ensure the USB device always has the same name, in this case: /dev/zwave (the code is poorly written, but it works):
cat > /etc/hotplug.d/usb/10-usb_hotplug <<EOF
# logger -t DEBUG "hotplug usb: action='\$ACTION' product='\$PRODUCT' type='\$TYPE' interface='\$INTERFACE'"
# logger -t DEBUG "hotplug usb: devicename='\$DEVICENAME' devname='\$DEVNAME' devpath='\$DEVPATH'"
  case "\$ACTION" in
  add)
    case "\$PRODUCT" in
    658/200/*)
      logger -t DEBUG "hotplug usb: Z-wave.me ZME_UZB1 has been connected!"
#     DEVICE_NAME=\$(ls /sys/\$DEVPATH | grep ttyA)
      DEVICE_NAME=\$(ls /dev | grep ttyACM*)
      logger -t DEBUG "hotplug usb: DEVICE_NAME='\$DEVICE_NAME'"
      if [ -z \${DEVICE_NAME} ];
           then logger -t DEBUG "hotplug usb: Warning DEVICE_NAME is empty"
           exit
      fi
      chmod a+rw /dev/\$DEVICE_NAME
      ln -sf /dev/\$DEVICE_NAME /dev/zwave
      logger -t DEBUG "hotplug usb: Symlink from /dev/\$DEVICE_NAME to /dev/zwave created"
    esac
  remove)
    case "\$PRODUCT" in
    658/200/*)
      logger -t DEBUG "hotplug usb: Z-wave.me ZME_UZB1 has been removed!"
      logger -t DEBUG "hotplug usb: Symlink from /dev/\$DEVICE_NAME to /dev/zwave destroyed"
    esac
  esac
EOF
Please note the text ‘658/200’, (found via lsusb) above, and ‘c 166’ (found via: ls -al /dev/tty*) below.
I note also you needed opkg install kmod-usb-serial-ftdi (for a RFXTRX433E), where I required opkg install kmod-usb-acm (for a zwave.me ZME-UZB1).
If you’re using LXC, I expose that USB device to LXC via:
if ! grep -q zwave /srv/lxc/${LXC_NAME}/config; then
    cat >> /srv/lxc/${LXC_NAME}/config << EOF
# for lsusb in LXC-Container, fix error message "unable to initialize libusb: -99"
# Setup USB passthrough for Z-Wave.me ZME-UZB1, with permissions a+rw (umask=000)
lxc.cgroup.devices.allow = c 166:* rwm
lxc.mount.entry = /dev/zwave  dev/zwave  none  bind,optional,create=file,umask=000  0 0
EOF
fi;
Some of this code has been shamelessly copied from elsewhere, and I am sorry for not being able to provide attributions - however the following were relevant;
Tryin to get DVB USB dongle on LXC, but still cant see any TV adapter in tvheadend :frowning_face:
Omnia - Tuner inside back USB port, 3.10.8
LXC - Debian Stretch
root@Doma:~ lsusb -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=dvb_usb_rtl28xxu, 480M
    |__ Port 1: Dev 5, If 1, Class=Vendor Specific Class, Driver=, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
root@Doma:~ lsusb
Bus 004 Device 005: ID 15f4:0131 HanfTek
Bus 003 Device 002: ID 174c:5106 ASMedia Technology Inc. Transcend StoreJet 25M3
root@Doma:~ ls -al /dev/bus/usb/004/005
crw-r--r--    1 root     root      189, 388 Nov 28 17:31 /dev/bus/usb/004/005
root@Doma:~ ls -la /dev/dvb/adapter0/
drwxr-xr-x    2 root     root           140 Nov 28 18:28 .
drwxr-xr-x    3 root     root            60 Nov 20 14:15 ..
crw-r--r--    1 root     root      212,   4 Nov 28 18:28 demux0
crw-r--r--    1 root     root      212,   5 Nov 28 18:28 dvr0
crw-r--r--    1 root     root      212,   3 Nov 28 18:28 frontend0
crw-r--r--    1 root     root      212,  19 Nov 28 18:28 frontend1
crw-r--r--    1 root     root      212,   7 Nov 28 18:28 net0
LXC Setup:
lxc.cgroup.devices.allow = c 189:* rwm
lxc.group.devices.allow = c 189:* rwm
lxc.mount.entry = /dev/dvb dev/dvb none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/bus/usb/001 dev/bus/usb/001 none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/bus/usb/002 dev/bus/usb/002 none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/bus/usb/003 dev/bus/usb/003 none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/bus/usb/004 dev/bus/usb/004 none bind,optional,create=dir 0 0
lxc.mount.entry = /dev/bus/usb/005 dev/bus/usb/005 none bind,optional,create=dir 0 0
lxc.mount.entry = /mnt/NAS mnt/NAS none bind,optional,create=dir 0 0
(tried different options here, 188,189,212, group, cgroup)
root@Debian:~ lsusb
Bus 003 Device 002: ID 174c:5106 ASMedia Technology Inc. ASM1051 SATA 3Gb/s bridge
root@Debian:~ lsusb -t
But still no luck. What I am doing wrong?
dmesg
[1071400.221346] usb 4-1: new high-speed USB device number 5 using xhci-hcd
[1071400.378084] usb 4-1: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[1071400.448336] usb 4-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[1071400.448409] DVB: registering new adapter (Astrometa DVB-T2)
[1071400.453887] i2c i2c-9: Added multiplexed i2c bus 10
[1071400.453898] rtl2832 9-0010: Realtek RTL2832 successfully attached
[1071400.456727] mn88473 9-0018: Panasonic MN88473 successfully attached
[1071400.456746] usb 4-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[1071400.456833] usb 4-1: DVB: registering adapter 0 frontend 1 (Panasonic MN88473)...
[1071400.456946] r820t 10-003a: creating new instance
[1071400.468420] r820t 10-003a: Rafael Micro r820t successfully identified
[1071400.468491] r820t 10-003a: attaching existing instance
[1071400.475361] r820t 10-003a: Rafael Micro r820t successfully identified
[1071400.481932] Registered IR keymap rc-empty
[1071400.482137] input: Astrometa DVB-T2 as /devices/platform/soc/soc:internal-regs/f10f8000.usb3/usb4/4-1/rc/rc0/input3
[1071400.482144] rc0: Astrometa DVB-T2 as /devices/platform/soc/soc:internal-regs/f10f8000.usb3/usb4/4-1/rc/rc0
[1071400.482271] usb 4-1: dvb_usb_v2: schedule remote query interval to 200 msecs
[1071400.498355] usb 4-1: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
EDIT: I managed acess USB device by running TVHeadend under root instead of hts user… Unfortunatelly, DVB-T2 is still doesnt tune anything :frowning:
Hi…In the “ID of container”.conf document, you add I think to anything you desire. However, you can add the “most noteworthy” organizer to permit all the under ones.
Also, in Proxmox rules, you allocate then the USB as per item ID and so forth
This way it doesn’t make any difference on the off chance that you change port.
Yet, in the event that you have more that one of similar USB things, you should separate with something different.
pcb turnkey assembly
