Trying to create an alpine lxc container I get the following:
lxc-create -n test -t download -- -d Alpine -r 3.18 -a armv7l
Flushing the cache...
Downloading the image index
Downloading the rootfs
Downloading the metadata
The image cache is now ready
Unpacking the rootfs
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Exiting with failure status due to previous errors
lxc-create: test: lxccontainer.c: create_run_template: 1627 Failed to create container from template
lxc-create: test: tools/lxc_create.c: main: 317 Failed to create container test
Seems the images on Index of /lxc/images/Alpine/3.18/armv7l/2023-12-31/ are broken. (look at the file size).
Same for 3.17. Edge does seem to work but endsup being a 3.9 version.
Rg,
Arnaud
