today we released Ludus package (part of 3.11.6 release). Ludus is a joint research project between the Stratosphere Research Laboratory and CZ.NIC.
Its goal is to apply Game Theory to honeypot deployment in order to increase the security of the users.
You can read more about the project in this article.
We would be glad if you join this effort by installing Ludus package to your router.
To install and run package simply do the following:
opkg update
opkg install ludus-gui #only if you what to install Dashboard application on your router
opkg install ludus
After install finish type these command to run Ludus permanently
/etc/init.d/ludus enable
/etc/init.d/ludus start
reboot
You should see new app icon in https://192.168.1.1 or you can access dashboard from http://192.168.1.1/ludus/ (or whatever your router IP address is).
If you have any problem please let me know here or via PM.
