The same problem here after two months with a brand new sim card and the original Lte pack.
The card is registered with the provider(“mnc”: 10) , the provider seems to provide lte network signal (“mcc”: 202,“mnc”: 10,“radio”: “lte”) but I only receive wcdma signal.
@Pepe Is there any method to debug this problem or should i through my onmia at the garbage?
root@Mik2:~# uqmi -d /dev/cdc-wdm0 --get-data-status
"disconnected"
root@Mik2:~# uqmi -d /dev/cdc-wdm0 --get-serving-system
"registration": "registered",
"plmn_mcc": 202,
"plmn_mnc": 10,
"plmn_description": "",
"roaming": false
root@Mik2:~# uqmi -d /dev/cdc-wdm0 --get-signal-info
"type": "hdr",
"rssi": -125,
"ecio": 5,
"io": -106,
"type": "wcdma",
"rssi": -83,
"ecio": 15
root@Mik2:~# uqmi -d /dev/cdc-wdm0 --network-scan
"network_info": [
"mcc": 202,
"mnc": 10,
"description": "WIND GR",
"status": [
"current_serving",
"home",
"not_forbidden",
"preferred"
"mcc": 202,
"mnc": 10,
"description": "WIND",
"status": [
"available",
"home",
"not_forbidden",
"preferred"
"mcc": 202,
"mnc": 10,
"status": [
"available",
"home",
"not_forbidden",
"preferred"
"mcc": 202,
"mnc": 5,
"description": "voda GR",
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"mcc": 202,
"mnc": 1,
"description": "C-OTE",
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"mcc": 202,
"mnc": 5,
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"mcc": 202,
"mnc": 1,
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"mcc": 202,
"mnc": 5,
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"mcc": 202,
"mnc": 1,
"status": [
"available",
"roaming",
"forbidden",
"not_preferred"
"radio_access_technology": [
"mcc": 202,
"mnc": 10,
"radio": "umts"
"mcc": 202,
"mnc": 10,
"radio": "lte"
"mcc": 202,
"mnc": 10,
"radio": "gsm"
"mcc": 202,
"mnc": 5,
"radio": "umts"
"mcc": 202,
"mnc": 1,
"radio": "lte"
"mcc": 202,
"mnc": 5,
"radio": "lte"
"mcc": 202,
"mnc": 1,
"radio": "umts"
"mcc": 202,
"mnc": 5,
"radio": "gsm"
"mcc": 202,
"mnc": 1,
"radio": "gsm"
root@Mik2:~# uqmi -d /dev/cdc-wdm0 --get-current-settings
"Out of call"
root@Mik2:~# gcom -d /dev/ttyUSB2
***SIM ERROR***
Check device port configuration.
Check SIM is inserted
Test SIM in a mobile phone?
root@Mik2:~# gcom -d /dev/ttyUSB3
SIM ready
Waiting for Registration..(120 sec max)
Registered on Home network: "WIND GR WIND GR",2
Signal Quality: 15,99
