LTE Modem do not work in Bridge mode with Turris
Hello Guys, I just change my ISP and get new LTE Modem ZTE WF830. When trying to connect turris to modem in bridge mode i’m getting DHCP error.
2018-01-25T21:01:16+01:00 notice netifd: wan (4212): udhcpc: sending select for 10.96.42.124
2018-01-25T22:01:19+01:00 notice netifd[3562]: Last message 'wan (4212): udhcpc: ’ repeated 1 times, suppressed by syslog-ng on turris
2018-01-25T21:01:19+01:00 notice netifd: wan (4212): udhcpc: received DHCP NAK
2018-01-25T21:01:22+01:00 notice netifd: wan (4212): udhcpc: sending select for 10.96.42.124
2018-01-25T22:01:25+01:00 notice netifd[3562]: Last message 'wan (4212): udhcpc: ’ repeated 1 times, suppressed by syslog-ng on turris
2018-01-25T21:01:25+01:00 notice netifd: wan (4212): udhcpc: received DHCP NAK
2018-01-25T21:01:28+01:00 notice netifd: wan (4212): udhcpc: sending select for 10.96.42.124
Connection in router mode does work but I would like to prevent having tripple NAT. I tried to reboot modem and turris many times but without luck. Any help is more than welcome
and when you connect your PC to the modem (in bridge mode) - what happens?
as from these messages I would assume that the problem is with settings/dhcp or so on modem side.
Hi Mike,
once i connect modem to my PC it get assigned ISP’s IP, so it is working as it should.
And what IP your PC gets? (and mask and GW)
