Hallo,
first i want to tell that this is the best router i ever used in my live. All worked well from the start, including the installation of the LTE-Modul, which i followed exactly your tutorial.
I also bought the same card as in the LTE-Pack, the Quectel EC20, so i don’t have to fuzzle around with drivers.
But when i change specific things on my router, the LTE-Cars stops working and will only work again, if i do the following steps:
- delete the whole interface (LTE)
- shutdown
- remove the card
- reboot
- mount the card again
- reboot
- install the LTE-Interface again
Otherwise the LTE-Symbol is greyed out in Luci and only RX and TX appear. No Uptime, MAC-Address and IPv4 stats.
Deleting the interface without removing the card didn’t work.
I have factory resetet the router like 5 times and tried to reproduce the bug.
I could reproduce it with the following:
When i configure in LUCI the LED’s for either the USB-Device or the netdev for the LTE-Interface AND renamed the Led’s, so it will not be resetet to default on reboot.
Change the SSID for the 5 GHz or the 2,4 GHz Wifi
Added a Guest-Wifi
So the best way would be to make all the changes to an Interface BEFORE setting up LTE, so you don’t run into trouble. This was exactly how i did it the first time i set up the router, so i didn’t ran into any problems.
But yesterday i had to change something, so i encountered this behaviour, which can be fixed with the steps above, but it cost me some time to figure that out.
I am not at home at the moment, so i have not any logs from my connection, but i can provide it, if necessary.
Edit: spelling
Update:
After days of testing, i came to the conclusion that the temp was the problem, the LTE Card simply got to hot, when under load, combined with the hot temps in the last weeks. So i applied a self build cooler, similar to that provided in the LTE Pack, a sawed aluminium piece. Now it works even under heavy load, without disconnecting. I would not have thought that this could be the problem, seems like a design flaw from the producer of these LTE-Cards, because my Smartphone can provide me with similar Speed, without the need for a Water-Cooling-Solution, and the LTE-Function from my smartphone is only one part of a complex computer-system.
But i am happy that my LTE now works and i could get rid of my “we don’t provide updates, our software is perfect from day 1” - Modem.
Edit: the bugs, when configuring interfaces still persist, but are minor, since you do not configure it on a daily base, but can be hard to track down.
