Hi everyone,
for years, I’ve used a BigClown / Hardwario set connected using their USB radio dongle to my Turris 1.1 router with Turris OS 3 without any problems. I admit, I didn’t update the system very often. Recently I’ve had that (too impulsive?) idea to update to the latest Turris OS 3.11.19.1. From that moment on, I am not receiving any new messages from the radio dongle to the mosquitto broker. It seems, that a python script called “bcg”, which serves as gateway between USB radio dongle and mosquitto, is not alive… The usual start command doesn’t return any error:
root@turris:/# /etc/init.d/bc-gateway-usb-dongle start
Generating bc-gateway-usb-dongle config file in /tmp/bc-gateway-usb-dongle.generated.conf
root@turris:/#
But it is not running either:
root@turris:/# ps | grep bcg
15674 root 1352 S grep bcg
root@turris:/#
If I try to run bcg manually in console, I get this:
root@turris:/# bcg --device /dev/ttyUSB0 --debug
2020-10-16 21:00:09,335 ERROR: Click will abort further execution because Python 3 was configured to use ASCII as encoding for the environment. Consult https://click.palletsprojects.com/python3/ for mitigation steps.
Additional information: on this system no suitable UTF-8 locales were discovered. This most likely requires resolving by reconfiguring the locale system.
root@turris:/#
So I’m probably having a compatibility issue of python 3 and the locale on my Turris. Setting locale to cs_CZ or en_US by exporting LC_ALL and LANG doesn’t help either, the “click” utility then reports, that locale is set, but not present in the system:
root@turris:/# export LC_ALL=cs_CZ.utf-8
root@turris:/# export LANG=cs_CZ.utf-8
root@turris:/# bcg --devices
2020-10-17 12:35:10,059 ERROR: Click will abort further execution because Python 3 was configured to use ASCII as encoding for the environment. Consult https://click.palletsprojects.com/python3/ for mitigation steps.
Click discovered that you exported a UTF-8 locale but the locale system could not pick up from it because it does not exist. The exported locale is ‘cs_CZ.utf-8’ but it is not supported
Any ideas how to fix it? Should I go back to one of previous versions of Turris OS?
Thank you in advance!
Martin
