Hi! I was wondering if the router will support link aggregation which can be managed in the Web UI.
Hello. Link aggregation is not natively supported in OpenWRT. This does not mean that it is impossible, but implementing it could be tricky and certainly not supported in the Web UI. Also bear in mind there are only two GbE links between the SoC and the switch chip so there will probably not be any significant performance benefit.
