dGs
October 11, 2022, 5:57am
1
I would like to know the best way to remove permanently lighttpd-https-cert because I already have my SSL config file.
I created a lua script to uninstall lighttpd-https-cert and install lighttpd-mod-openssl, is it the best way?
Next since Turris 6.0 I have a problem with my reverse proxy configured to access app on my LXC container.
If those apps have a /login , accessing Domain.com will redirect me to turris-auth.
I haven’t find a way to configure lighttpd to ignore turris-auth for proxied Host :
$HTTP[“host”] == “app.domain.com ” ( … )
Thanks
dGs
October 14, 2022, 12:03am
2
Reply to myself :
cat /etc/updater/conf.d/ssl.lua
Uninstall("lighttpd-https-cert", { priority = 60 })
Install("lighttpd-mod-openssl")
Seems to work.
And for the reverse proxy, I replaced 50-turris-auth.conf by the result of the command ‘turris-auth-server --lighttpd-config --luci-login’
And added around the fastcgi section :
$HOST["host"] =~ "regex to match my dns and local ip" { ... }
Now turris-auth won’t intercept /login, /logout, from my lighttpd reverse proxy.
Out of interest, are you using lighttpd as a reverse proxy? are you happy with the performance overall?
dGs
October 14, 2022, 6:51pm
4
Yes I use lighttpd to access WikiJs, Bookstack and Gitea installed on the Turris in a LXC container for each apps.
But only one user, me. No intensive usage. So it’s okay for my usage.
system
Closed
October 17, 2022, 6:52pm
5
