/www/luci-static/resources/view/acme.js
'use strict';'require form';'require fs';'require view';return view.extend({load:function(){return Promise.all([L.resolveDefault(fs.stat('/usr/sbin/nginx'),{}),L.resolveDefault(fs.stat('/usr/sbin/uhttpd'),{}),L.resolveDefault(fs.stat('/usr/sbin/lighttpd'),{})]);},render:function(stats){var m,s,o;m=new form.Map("acme",_("ACME certificates"),_("This configures ACME (Letsencrypt) automatic certificate installation. "+"Simply fill out this to have the router configured with Letsencrypt-issued "+"certificates for the web interface. "+"Note that the domain names in the certificate must already be configured to "+"point at the router's public IP address. "+"Once configured, issuing certificates can take a while. "+"Check the logs for progress and any errors."));s=m.section(form.TypedSection,"acme",_("ACME global config"));s.anonymous=true;o=s.option(form.Value,"state_dir",_("State directory"),_("Where certs and other state files are kept."));o.rmempty=false;o.datatype="directory";o=s.option(form.Value,"account_email",_("Account email"),_("Email address to associate with account key."))
o.rmempty=false;o.datatype="minlength(1)";o=s.option(form.Flag,"debug",_("Enable debug logging"));o.rmempty=false;s=m.section(form.GridSection,"cert",_("Certificate config"))
s.anonymous=false;s.addremove=true;s.nodescriptions=true;o=s.tab("general",_("General Settings"));o=s.tab("challenge",_("Challenge Validation"));o=s.tab("advanced",_('Advanced Settings'));o=s.taboption('general',form.Flag,"enabled",_("Enabled"));o.rmempty=false;o=s.taboption('general',form.Flag,"use_staging",_("Use staging server"),_("Get certificate from the Letsencrypt staging server "+"(use for testing; the certificate won't be valid)."));o.rmempty=false;o.modalonly=true;o=s.taboption('general',form.ListValue,"keylength",_("Key size"),_("Key size (and type) for the generated certificate."));o.value("2048",_("RSA 2048 bits"));o.value("3072",_("RSA 3072 bits"));o.value("4096",_("RSA 4096 bits"));o.value("ec-256",_("ECC 256 bits"));o.value("ec-384",_("ECC 384 bits"));o.default="2048";o.rmempty=false;o=s.taboption('general',form.DynamicList,"domains",_("Domain names"),_("Domain names to include in the certificate. "+"The first name will be the subject name, subsequent names will be alt names. "+"Note that all domain names must point at the router in the global DNS."));o.datatype="list(string)";if(stats[2].type==='file'){o=s.taboption('general',form.Flag,"update_lighttpd",_("Use for lighttpd"),_("Update the lighttpd config with this certificate once issued "+"(only select this for one certificate). "+"lighttpd must support ssl"));o.rmempty=false;o.modalonly=true;}if(stats[1].type==='file'){o=s.taboption('general',form.Flag,"update_uhttpd",_("Use for uhttpd"),_("Update the uhttpd config with this certificate once issued "+"(only select this for one certificate). "+"Is also available luci-app-uhttpd to configure uhttpd form the LuCI interface."));o.rmempty=false;o.modalonly=true;}
if(stats[0].type==='file'){o=s.taboption('general',form.Flag,"update_nginx",_("Use for nginx"),_("Update the nginx config with this certificate once issued "+"(only select this for one certificate). "+"Nginx must support ssl, if not it won't start as it needs to be "+"compiled with ssl support to use cert options"));o.rmempty=false;o.modalonly=true;}
o=s.taboption('challenge',form.ListValue,"validation_method",_("Validation method"),_("Standalone mode will use the built-in webserver of acme.sh to issue a certificate. "+"Webroot mode will use an existing webserver to issue a certificate. "+"DNS mode will allow you to use the DNS API of your DNS provider to issue a certificate."));o.value("standalone",_("Standalone"));o.value("webroot",_("Webroot"));o.value("dns",_("DNS"));o.default="standalone";o=s.taboption('challenge',form.Value,"webroot",_("Webroot directory"),_("Webserver root directory. Set this to the webserver "+"document root to run Acme in webroot mode. The web "+"server must be accessible from the internet on port 80."));o.optional=true;o.depends("validation_method","webroot");o.modalonly=true;o=s.taboption('challenge',form.Value,"dns",_("DNS API"),_("To use DNS mode to issue certificates, set this to the name of a DNS API supported by acme.sh. "+"See https://github.com/acmesh-official/acme.sh/wiki/dnsapi for the list of available APIs. "+"In DNS mode, the domain name does not have to resolve to the router IP. "+"DNS mode is also the only mode that supports wildcard certificates. "+"Using this mode requires the acme-dnsapi package to be installed."));o.depends("validation_method","dns");o.modalonly=true;o=s.taboption('challenge',form.DynamicList,"credentials",_("DNS API credentials"),_("The credentials for the DNS API mode selected above. "+"See https://github.com/acmesh-official/acme.sh/wiki/dnsapi for the format of credentials required by each API. "+"Add multiple entries here in KEY=VAL shell variable format to supply multiple credential variables."))
o.datatype="list(string)";o.depends("validation_method","dns");o.modalonly=true;o=s.taboption('challenge',form.Value,"calias",_("Challenge Alias"),_("The challenge alias to use for ALL domains. "+"See https://github.com/acmesh-official/acme.sh/wiki/DNS-alias-mode for the details of this process. "+"LUCI only supports one challenge alias per certificate."));o.depends("validation_method","dns");o.modalonly=true;o=s.taboption('challenge',form.Value,"dalias",_("Domain Alias"),_("The domain alias to use for ALL domains. "+"See https://github.com/acmesh-official/acme.sh/wiki/DNS-alias-mode for the details of this process. "+"LUCI only supports one challenge domain per certificate."));o.depends("validation_method","dns");o.modalonly=true;o=s.taboption('advanced',form.Flag,"use_acme_server",_("Custom ACME CA"),_("Use a custom CA instead of Let's Encrypt."));o.depends("use_staging","0");o.default=false;o.modalonly=true;o=s.taboption('advanced',form.Value,"acme_server",_("ACME server URL"),_("Custom ACME server directory URL."));o.depends("use_acme_server","1");o.placeholder="https://api.buypass.com/acme/directory";o.optional=true;o.modalonly=true;o=s.taboption('advanced',form.Value,'days',_('Days until renewal'));o.optional=true;o.placeholder=90;o.datatype='uinteger';return m.render()}})
It adds native support to cert update of lighttpd web server that configure from LuCI.
