I am having strange issues with reboots. Sometimes sshd does not come up, I get “Connection refused”. Luci shows sshd process is indeed not running, log does not have any messages from sshd. Luci, Startup, sshd is enabled. Click Start or Restart, sshd starts up without issues. Other boots is starts up fine.
LEDs sometimes all come up blue after a reboot. Router is working fine. Running /etc/rc.d/S99start-indicator returns LEDs to the desired config.
I am at loss on what is happening.
While looking at start-indicator noticed it should also log “Router Turris successfully started.” In my log it is right up among the first kernel boot messages when it should be the last rc scripts run. Is this just a log buffer issue?
Sep 28 18:06:49 turris syslog-ng[2769]: syslog-ng starting up; version='4.2.0'
Sep 28 18:06:49 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Sep 28 18:06:49 turris kernel: [ 0.000000] Linux version 5.15.127 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 8.4.0 r16862+127-170d9e447d) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Thu Aug 24 08:16:54 2023
Sep 28 18:06:49 turris kernel: [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Sep 28 18:06:49 turris kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Sep 28 18:06:49 turris kernel: [ 0.000000] OF: fdt: Machine model: Turris Omnia
Sep 28 18:06:49 turris kernel: [ 0.000000] Memory policy: Data cache writealloc
Sep 28 18:06:49 turris kernel: [ 0.000000] Zone ranges:
Sep 28 18:06:49 turris kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
Sep 28 18:06:49 turris kernel: [ 0.000000] HighMem [mem 0x0000000030000000-0x000000003fffffff]
Sep 28 18:06:49 turris kernel: [ 0.000000] Movable zone start for each node
Sep 28 15:06:49 turris turris: Router Turris successfully started.
Sep 28 18:06:49 turris kernel: [ 0.000000] Early memory node ranges
