Because sometimes a flash drive in the /srv/ position fails and it is necessary to occasionally question its status … /foris/config/main/storage/ . It would be more convenient if it were possible for the LED at the User position to signal its connection … and optimally the LED flickering off when writing in progress.
TOS 5.1.10, branch hbs
How to set rainbow and LED configuration to USER 2 position to signal a functional (connected) flash drive and by turning off the light in progress writing to the disk. So far, all I’ve done is get the LED signaling a resued flash drive.
/etc/config/rainbow
config led 'usr2'
option color '310431'
option status 'auto'
/etc/config/system
config led
option sysfs 'omnia-led:user2'
option name 'srv'
option default '1'
option trigger 'usbdev'
option dev '2-1'
i have two usb drives (one is for “srv” and second as “backup storage”) and both are assigned to user2-led, which is off and flashes when there is write/read. Some time ago (many TOS updates back), there was trigger for writes or reads available, now there is just “usbdev”.
Here is my setup …
config led
option name 'USB1'
option dev '3-1'
option default '0'
config led
option name 'USB2'
option dev '5-1'
option default '0'
and rainbow
config led 'usr2'
option color '8303CC'
It doesn’t work for me. As long as I had a flash drive with a light on it, I saw the entry as soon as 20 sec. Now I’ve been looking for two minutes and I can’t see anything…
Rainbow: User2, auto
LED config: omnia-led:usr2, Default state off (zero), USB device 2-1 (Generic USN storage)
this occurs time to time to me as well, it depends if i change “system” and later “rainbow” or vice versa or change and apply both at once.I have to wait a bit or i just restart one or the other service again (usually that helps , so i do not care much when it does not on first try ; but sure i can confuse …
