I found someone else trying this:
But I don’t have the problem they faced. I think.
I just found this:
https://knot-resolver.readthedocs.io/en/latest/modules-http-trace.html
And would like to have that available.
So yes, I have a:
# cat /etc/kresd/custom.conf
modules.load('http')
hints.add_hosts()
and I restart:
# /etc/init.d/resolver restart
Called /etc/init.d/kresd stop
set dhcp script
Called /etc/init.d/kresd start
set dhcp script
Called /etc/resolver/dhcp_host_domain_ng.py
So I expect it to be listening on port 8453 but:
netstat -tulpen | grep 8453
produces nothing. And a full list of kresd ports:
# netstat -tulpen | grep kresd
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 10735/kresd
tcp 0 0 :::53 :::* LISTEN 10735/kresd
udp 0 0 0.0.0.0:42532 0.0.0.0:* 10735/kresd
udp 0 0 0.0.0.0:57390 0.0.0.0:* 10735/kresd
udp 0 0 0.0.0.0:53 0.0.0.0:* 10735/kresd
udp 0 0 0.0.0.0:42143 0.0.0.0:* 10735/kresd
udp 0 0 0.0.0.0:39787 0.0.0.0:* 10735/kresd
udp 0 0 :::53 :::* 10735/kresd
shows me it’s listening only on 53 (though I wonder what the other ports are for).
If I tail -f messages
and restart kresd I see only this appear:
2021-03-10 21:19:25 err kresd[12059]: deprecation WARNING: use --noninteractive instead of --forks=1
2021-03-10 21:19:25 info kresd[12059]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
2021-03-10 21:19:25 info kresd[12059]: [ta_update] refreshing TA for .
2021-03-10 21:19:25 info kresd[12059]: [ta_update] next refresh for . in 23.9075 hours
2021-03-10 21:19:26 warning /dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2021-03-10 21:19:26 warning /dhcp_host_domain_ng.py[13938]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Cerberus.lan
2021-03-10 21:19:26 info /dhcp_host_domain_ng.py[]: Refresh kresd leases
which highlights to config errors (that I have no idea how to fix, a --noninteractive error and hard limit for number of file descriptors warning), but does not show any other issues, neither a sign of success or failure in loading the http module.
What am I doing wrong?
