Dear Turris users,
we have registered a couple of bugs, which have come up with the release of Turris OS 3.9. They should be marginal problems and only affect a small number of users. We are working on solving the bugs as quickly as possible and want to apologize for any inconvenience they might cause you:
- if you have any trouble with Updater, please try to first reboot the router.
- Updater fails on packages, which users have created themselves. A fix will be released in Turris OS 3.9.1.
- An error in Foris, which causes the SSH Honeypot option to be Unchecked. Please check that you have this window checked (if you want it to be), the solution is to check the option again.
Thanks for your understanding and happy routing,
Team Turris
