Hello.
I’m trying to enable the HTTP module in Knot resolver but with no luck so far. I wanted to trace some DNS issues I’m facing with the tracking service.
However it was complaining about missing cqueues Lua module:
error: /usr/lib/kres_modules/http.lua:6: module ‘cqueues’ not found:
So I installed the missing module:
opkg install lua-cqueues
and reloaded kresd again. But got the same error. I noticed that the cqueues module has been installed on path /usr/lib/lua, however this path is not on the kresd search path:
no field package.preload[‘cqueues’]
no file ‘/usr/lib/cqueues.lua’
no file ‘/usr/lib/cqueues/init.lua’
no file ‘./cqueues.lua’
no file ‘/usr/share/luajit-2.0.5/cqueues.lua’
no file ‘/usr/local/share/lua/5.1/cqueues.lua’
no file ‘/usr/local/share/lua/5.1/cqueues/init.lua’
no file ‘/usr/share/lua/5.1/cqueues.lua’
no file ‘/usr/share/lua/5.1/cqueues/init.lua’
no file ‘/usr/lib/cqueues.so’
no file ‘./cqueues.so’
no file ‘/usr/local/lib/lua/5.1/cqueues.so’
no file ‘/usr/lib/lua/5.1/cqueues.so’
no file ‘/usr/local/lib/lua/5.1/loadall.so’
I made a symlink from /usr/lib/lua to one of the listed paths and now I’m stuck with this error:
error: /usr/lib/kres_modules/http.lua:6: loop or previous error loading module ‘cqueues’
The biggest problem I see is that the module absolutely can’t work without the lua-http package, and that’s not packaged for Turris yet (not even 5.0.0 HBT).
cqueues is only needed for some quite specific functions; almost no Turris users will benefit from it, I believe. Therefore it seems OK to me not to pull that dependency by default, even though on Turris devices we surely don’t need to be as minimalist as openwrt defaults.
It most likely won’t help your case, but there’s a public instance of the service here: https://debug.knot-resolver.cz/query.py?qtype=A&qname=turris.cz Well, if you discover some reproducible bugs in Knot Resolver through the service, we’ll certainly be interested.
Ok, I tried to install it with luarocks, but it tries to pull in a buch of other dependencies, some of them trying to compile from sources. I’m giving up…
Then maybe the HTTP module could be packaged separately as knot-resolver-module-http with this package having the required dependencies, couldn’t it?
Great, good to know, thanks.
Anyway, does the HTTP tracking service provide any additional information or benefit over the resolver-debug package? It seems to me that the output from from the public service you mentioned is the same as the debug logs I can already retrieve.
Yes, that’s how we typically package it for Linux distributions, so I assume we would aim for the same here as well.
Yes, the tracing in http displays the verbose log; the main advantage is that you see a separate log just for one particular request. The http module also has some other features (e.g. DNS-over-HTTPS), but you don’t seem interested in those.
In verbose logs we try to attribute every line to a client’s request and mark it [NNNNN. by the ID sent from the client, so that can be also used for separating them afterwards.
