Zdravim,
narazil sem na divnej problem, jedna konkretni ip (213.192.19.10) se ke me nemuze dostat a ja se nemuzu dostat k ni (ani ping nebo tracert).
Po restartu routeru chvilku vsechno slape, pote dostavam chybu:
root@turris:~# ping 213.192.19.10
PING 213.192.19.10 (213.192.19.10): 56 data bytes
ping: sendto: Operation not permitted
root@turris:~# traceroute 213.192.19.10
traceroute to 213.192.19.10 (213.192.19.10), 30 hops max, 38 byte packets
1traceroute: sendto: Operation not permitted
Adresy 213.192.19.1 213.192.19.9 213.192.19.11 jedou bez problemu, je to jen tahle konkretni ip.
ve FW nevidim zadne pravidlo ktere by provoz melo blokovat. Nejakej napad na reseni?
root@turris:~# iptables -S
-P INPUT DROP
-P FORWARD DROP
-P OUTPUT DROP
-N MINIUPNPD
-N accept
-N drop
-N forwarding_lan_rule
-N forwarding_rule
-N forwarding_wan_rule
-N input_lan_rule
-N input_rule
-N input_wan_rule
-N output_lan_rule
-N output_rule
-N output_wan_rule
-N reject
-N syn_flood
-N turris
-N turris-log-incoming
-N turris-nflog
-N ucollect_fake
-N ucollect_fake_accept
-N zone_lan_dest_accept
-N zone_lan_forward
-N zone_lan_input
-N zone_lan_output
-N zone_lan_src_accept
-N zone_wan_dest_REJECT
-N zone_wan_dest_accept
-N zone_wan_forward
-N zone_wan_input
-N zone_wan_output
-N zone_wan_src_REJECT
-A INPUT -i lo -m comment --comment "!fw3" -j ACCEPT
-A INPUT -m comment --comment "!fw3: user chain for input" -j input_rule
-A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3" -j ACCEPT
-A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m comment --comment "!fw 3" -j syn_flood
-A INPUT -i br-lan -m comment --comment "!fw3" -j zone_lan_input
-A INPUT -i eth2 -m comment --comment "!fw3" -j zone_wan_input
-A INPUT -m comment --comment "!fw3" -j accept
-A FORWARD -m comment --comment "!fw3: user chain for forwarding" -j forwarding_ rule
-A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3 " -j ACCEPT
-A FORWARD -i br-lan -m comment --comment "!fw3" -j zone_lan_forward
-A FORWARD -i eth2 -m comment --comment "!fw3" -j zone_wan_forward
-A FORWARD -m comment --comment "!fw3" -j reject
-A OUTPUT -o lo -m comment --comment "!fw3" -j ACCEPT
-A OUTPUT -m comment --comment "!fw3: user chain for output" -j output_rule
-A OUTPUT -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3" -j ACCEPT
-A OUTPUT -o br-lan -m comment --comment "!fw3" -j zone_lan_output
-A OUTPUT -o eth2 -m comment --comment "!fw3" -j zone_wan_output
-A OUTPUT -m comment --comment "!fw3" -j accept
-A accept -j turris
-A accept -m comment --comment "!fw3" -j ACCEPT
-A drop -i eth2 -j turris-log-incoming
-A drop -m comment --comment "!fw3" -j DROP
-A forwarding_rule -j turris-nflog
-A input_rule -j turris-nflog
-A output_rule -j turris-nflog
-A reject -i eth2 -j turris-log-incoming
-A reject -p tcp -m comment --comment "!fw3" -j REJECT --reject-with tcp-reset
-A reject -m comment --comment "!fw3" -j REJECT --reject-with icmp-port-unreacha ble
-A syn_flood -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 25/s ec --limit-burst 50 -m comment --comment "!fw3" -j RETURN
-A syn_flood -m comment --comment "!fw3" -j DROP
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00005E11_l_a_ 4_X dst -j LOG --log-prefix "turris-00005E11: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00005E11_l_a_ 4_X src -j LOG --log-prefix "turris-00005E11: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00415B11_l_a_ 4_X dst -j LOG --log-prefix "turris-00415B11: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00415B11_l_a_ 4_X src -j LOG --log-prefix "turris-00415B11: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00557B71_l_ap _4_X dst,dst -j LOG --log-prefix "turris-00557B71: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00557B71_l_ap _4_X src,src -j LOG --log-prefix "turris-00557B71: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_007E0511_l_a_ 4_X dst -j LOG --log-prefix "turris-007E0511: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_007E0511_l_a_ 4_X src -j LOG --log-prefix "turris-007E0511: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_009A7E41_l_a_ 4_X dst -j LOG --log-prefix "turris-009A7E41: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_009A7E41_l_a_ 4_X src -j LOG --log-prefix "turris-009A7E41: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00A704A1_l_a_ 4_X dst -j LOG --log-prefix "turris-00A704A1: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00A704A1_l_a_ 4_X src -j LOG --log-prefix "turris-00A704A1: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00CE6700_lb_a _4_X dst -j LOG --log-prefix "turris-00CE6700: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00CE6700_lb_a _4_X src -j LOG --log-prefix "turris-00CE6700: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00CE6701_l_a_ 4_X dst -j LOG --log-prefix "turris-00CE6701: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00CE6701_l_a_ 4_X src -j LOG --log-prefix "turris-00CE6701: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00D05711_l_a_ 4_X dst -j LOG --log-prefix "turris-00D05711: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00D05711_l_a_ 4_X src -j LOG --log-prefix "turris-00D05711: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00DEAD51_l_a_ 4_X dst -j LOG --log-prefix "turris-00DEAD51: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00DEAD51_l_a_ 4_X src -j LOG --log-prefix "turris-00DEAD51: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00DEB060_lb_a _4_X dst -j LOG --log-prefix "turris-00DEB060: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00DEB060_lb_a _4_X src -j LOG --log-prefix "turris-00DEB060: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_00FE0D01_l_a_ 4_X dst -j LOG --log-prefix "turris-00FE0D01: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_00FE0D01_l_a_ 4_X src -j LOG --log-prefix "turris-00FE0D01: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_047C0DE1_l_a_ 4_X dst -j LOG --log-prefix "turris-047C0DE1: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_047C0DE1_l_a_ 4_X src -j LOG --log-prefix "turris-047C0DE1: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_06E7E701_l_a_ 4_X dst -j LOG --log-prefix "turris-06E7E701: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_06E7E701_l_a_ 4_X src -j LOG --log-prefix "turris-06E7E701: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_07E7E411_l_a_ 4_X dst -j LOG --log-prefix "turris-07E7E411: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_07E7E411_l_a_ 4_X src -j LOG --log-prefix "turris-07E7E411: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_0A566041_l_ap _4_X dst,dst -j LOG --log-prefix "turris-0A566041: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_0A566041_l_ap _4_X src,src -j LOG --log-prefix "turris-0A566041: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_0A7D7011_l_a_ 4_X dst -j LOG --log-prefix "turris-0A7D7011: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_0A7D7011_l_a_ 4_X src -j LOG --log-prefix "turris-0A7D7011: " --log-level 7
-A turris -o eth2 -m limit --limit 1/sec -m set --match-set turris_100FA4E0_lb_a _4_X dst -j LOG --log-prefix "turris-100FA4E0: " --log-level 7
-A turris -i eth2 -m limit --limit 1/sec -m set --match-set turris_100FA4E0_lb_a _4_X src -j LOG --log-prefix "turris-100FA4E0: " --log-level 7
-A turris -o eth2 -m set --match-set turris_00CE6700_lb_a_4_X dst -j DROP
-A turris -i eth2 -m set --match-set turris_00CE6700_lb_a_4_X src -j DROP
-A turris -o eth2 -m set --match-set turris_00DEB060_lb_a_4_X dst -j DROP
-A turris -i eth2 -m set --match-set turris_00DEB060_lb_a_4_X src -j DROP
-A turris -o eth2 -m set --match-set turris_100FA4E0_lb_a_4_X dst -j DROP
-A turris -i eth2 -m set --match-set turris_100FA4E0_lb_a_4_X src -j DROP
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00005E11 _l_a_4_X src -j LOG --log-prefix "turris-00005E11: " --log-level 7
-A turris-log-incoming -j ucollect_fake
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00415B11 _l_a_4_X src -j LOG --log-prefix "turris-00415B11: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00557B71 _l_ap_4_X src,src -j LOG --log-prefix "turris-00557B71: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_007E0511 _l_a_4_X src -j LOG --log-prefix "turris-007E0511: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_009A7E41 _l_a_4_X src -j LOG --log-prefix "turris-009A7E41: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00A704A1 _l_a_4_X src -j LOG --log-prefix "turris-00A704A1: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00CE6700 _lb_a_4_X src -j LOG --log-prefix "turris-00CE6700: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00CE6701 _l_a_4_X src -j LOG --log-prefix "turris-00CE6701: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00D05711 _l_a_4_X src -j LOG --log-prefix "turris-00D05711: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00DEAD51 _l_a_4_X src -j LOG --log-prefix "turris-00DEAD51: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00DEB060 _lb_a_4_X src -j LOG --log-prefix "turris-00DEB060: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_00FE0D01 _l_a_4_X src -j LOG --log-prefix "turris-00FE0D01: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_047C0DE1 _l_a_4_X src -j LOG --log-prefix "turris-047C0DE1: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_06E7E701 _l_a_4_X src -j LOG --log-prefix "turris-06E7E701: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_07E7E411 _l_a_4_X src -j LOG --log-prefix "turris-07E7E411: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_0A566041 _l_ap_4_X src,src -j LOG --log-prefix "turris-0A566041: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_0A7D7011 _l_a_4_X src -j LOG --log-prefix "turris-0A7D7011: " --log-level 7
-A turris-log-incoming -m limit --limit 1/sec -m set --match-set turris_100FA4E0 _lb_a_4_X src -j LOG --log-prefix "turris-100FA4E0: " --log-level 7
-A turris-log-incoming -m set --match-set turris_00005E11_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00415B11_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00557B71_l_ap_4_X src,src -j RE TURN
-A turris-log-incoming -m set --match-set turris_007E0511_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_009A7E41_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00A704A1_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00CE6700_lb_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00CE6701_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00D05711_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00DEAD51_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00DEB060_lb_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_00FE0D01_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_047C0DE1_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_06E7E701_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_07E7E411_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_0A566041_l_ap_4_X src,src -j RE TURN
-A turris-log-incoming -m set --match-set turris_0A7D7011_l_a_4_X src -j RETURN
-A turris-log-incoming -m set --match-set turris_100FA4E0_lb_a_4_X src -j RETURN
-A turris-log-incoming -m limit --limit 1/sec --limit-burst 500 -j LOG --log-pre fix "turris-00000000: " --log-level 7
-A ucollect_fake -m mark --mark 0x80000/0xc0000 -m limit --limit 100/sec --limit -burst 200 -j LOG --log-prefix "ucollect-fake-open-inet: " --log-level 7
-A ucollect_fake -m mark --mark 0x80000/0xc0000 -j DROP
-A ucollect_fake_accept -p tcp -m tcp --dport 3692 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A ucollect_fake_accept -p tcp -m tcp --dport 1392 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A ucollect_fake_accept -p tcp -m tcp --dport 4497 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A ucollect_fake_accept -p tcp -m tcp --dport 9449 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A ucollect_fake_accept -p tcp -m tcp --dport 1449 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A ucollect_fake_accept -p tcp -m tcp --dport 9492 -m mark --mark 0xc0000/0xc000 0 -j ACCEPT
-A zone_lan_dest_accept -o br-lan -m comment --comment "!fw3" -j accept
-A zone_lan_forward -m comment --comment "!fw3: user chain for forwarding" -j fo rwarding_lan_rule
-A zone_lan_forward -d 93.171.172.221/32 -m comment --comment "!fw3: block" -j z one_wan_dest_REJECT
-A zone_lan_forward -d 192.200.123.108/32 -m comment --comment "!fw3: block2" -j zone_wan_dest_REJECT
-A zone_lan_forward -m comment --comment "!fw3: forwarding lan -> wan" -j zone_w an_dest_accept
-A zone_lan_forward -m conntrack --ctstate DNAT -m comment --comment "!fw3: Acce pt port forwards" -j accept
-A zone_lan_forward -m comment --comment "!fw3" -j zone_lan_dest_accept
-A zone_lan_input -m comment --comment "!fw3: user chain for input" -j input_lan _rule
-A zone_lan_input -p igmp -m comment --comment "!fw3: ubus:igmpproxy[instance1] rule 2" -j accept
-A zone_lan_input -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port redirections" -j accept
-A zone_lan_input -m comment --comment "!fw3" -j zone_lan_src_accept
-A zone_lan_output -m comment --comment "!fw3: user chain for output" -j output_ lan_rule
-A zone_lan_output -m comment --comment "!fw3" -j zone_lan_dest_accept
-A zone_lan_src_accept -i br-lan -m conntrack --ctstate NEW,UNTRACKED -m comment --comment "!fw3" -j accept
-A zone_wan_dest_REJECT -o eth2 -m comment --comment "!fw3" -j reject
-A zone_wan_dest_accept -o eth2 -m conntrack --ctstate INVALID -m comment --comm ent "!fw3: Prevent NAT leakage" -j DROP
-A zone_wan_dest_accept -o eth2 -m comment --comment "!fw3" -j accept
-A zone_wan_forward -j MINIUPNPD
-A zone_wan_forward -m comment --comment "!fw3: user chain for forwarding" -j fo rwarding_wan_rule
-A zone_wan_forward -d 224.0.0.0/4 -p udp -m comment --comment "!fw3: ubus:igmpp roxy[instance1] rule 1" -j zone_lan_dest_accept
-A zone_wan_forward -s 89.233.171.0/24 -p udp -m comment --comment "!fw3: IPTV_j edna" -j accept
-A zone_wan_forward -s 224.0.0.0/4 -p udp -m comment --comment "!fw3: IPTV_dva" -j accept
-A zone_wan_forward -s 212.96.179.0/24 -p udp -m comment --comment "!fw3: IPTV_t ri" -j accept
-A zone_wan_forward -s 89.233.172.0/24 -p udp -m comment --comment "!fw3: IPTV_s est" -j accept
-A zone_wan_forward -s 232.0.2.0/24 -p udp -m comment --comment "!fw3: IPTV_sedu m" -j accept
-A zone_wan_forward -s 232.0.1.0/24 -p udp -m comment --comment "!fw3: IPTV_deve t" -j accept
-A zone_wan_forward -m conntrack --ctstate DNAT -m comment --comment "!fw3: Acce pt port forwards" -j accept
-A zone_wan_forward -m comment --comment "!fw3" -j zone_wan_dest_REJECT
-A zone_wan_input -m comment --comment "!fw3: user chain for input" -j input_wan _rule
-A zone_wan_input -p igmp -m comment --comment "!fw3: ubus:igmpproxy[instance1] rule 0" -j accept
-A zone_wan_input -p igmp -m comment --comment "!fw3: IGMP_ENABLE" -j accept
-A zone_wan_input -s 212.96.179.0/24 -p tcp -m comment --comment "!fw3: IPTV_cty ri" -j accept
-A zone_wan_input -s 212.96.179.0/24 -p udp -m comment --comment "!fw3: IPTV_cty ri" -j accept
-A zone_wan_input -s 89.233.171.134/32 -p tcp -m comment --comment "!fw3: IPTV_p et" -j accept
-A zone_wan_input -s 89.233.171.134/32 -p udp -m comment --comment "!fw3: IPTV_p et" -j accept
-A zone_wan_input -s 232.0.2.0/24 -p tcp -m comment --comment "!fw3: IPTV_osum" -j accept
-A zone_wan_input -s 232.0.2.0/24 -p udp -m comment --comment "!fw3: IPTV_osum" -j accept
-A zone_wan_input -s 232.0.1.0/24 -p tcp -m comment --comment "!fw3: IPTV_deset" -j accept
-A zone_wan_input -s 232.0.1.0/24 -p udp -m comment --comment "!fw3: IPTV_deset" -j accept
-A zone_wan_input -p udp -m udp --dport 68 -m comment --comment "!fw3: Allow-DHC P-Renew" -j accept
-A zone_wan_input -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port redirections" -j accept
-A zone_wan_input -m comment --comment "!fw3" -j zone_wan_src_REJECT
-A zone_wan_output -m comment --comment "!fw3: user chain for output" -j output_ wan_rule
-A zone_wan_output -m comment --comment "!fw3" -j zone_wan_dest_accept
-A zone_wan_src_REJECT -i eth2 -m comment --comment "!fw3" -j reject
