I was unable to receive a an IP address from my ISP. After some digging I assume that the problem is with the SFP transceiver or the cable or the Omnia itself.
I noticed that tcpdump showed no traffic on the WAN interface, even if I ran udhcpc on it.
cat /sys/class/net/eth2/carrier is always 0 no matter what I plug in.
eth2 is the wan interface according to /etc/config/network.
I have two SFP transceivers and patch cables. All of them I’ve tested with my old router and internet connection.
They are SFP-31W2ASM-10-DR and Siligence, SGA 441SFPO-1Gb, 1.25G T1310nm/R1490nm 10 km DDM.
Is it possible that these are incompatible with the Turris Omnia? I’m starting to reach my wit’s end.
if it being an Omnia with hardware revision not CZ11NIC23 and TOS => 4.x then
it is known that some SFP modules facing trouble that is mostly caused due the SFP implementation by upstream sources (OpenWrt and/or Linux). The systemlog does provide some output in regards to SFP.
I have a CZ11NIC20, but I flashed the newest OS version. Anyway, the symlink didn’t change anything.
One transceiver produces a bunch of “sfp sfp: no PHY” messages.
With the other I get mvneta f1034000.ethernet eth2: validation of 802.3z/1000base-x with support 00000,00002440 failed: -22.
If I wanted to take advantage of the more recent SFP changes in the Kernel, would I have to compile my own kernel?
Are there any other OS which might have better hardware support? OpenWRT? FreeBSD? OpenBSD?
Thank you for the useful feedback. TOS 6 will use OpenWrt 20.x branch with kernel 5.4 and better SFP support. Furthermore it depends also on the received backported patches. The good news is EOL of OpenWrt 19.07 and probably also TOS 5 in January 2021.
This is a brief statement of the facts that the further elaborated @anon50890781.
I ordered a new SFP transceiver from my ISP, who configured it for the Turris Omnia. It’s still not recognized. Is my Omnia broken? I don’t understand this.
Thank you for the message. I am using same transceiver (from ISP Swiss Sunrise) as you had problem with (LCS SFP-31W2ASM-10-DR). It still does not work on TOS 5.1.4
In your latest post you are mentionig that you got new SFP that works now, would you mind sharing model please?
@siska Sorry for the late reply. I ended up getting a new transceiver from my ISP (Init7). It worked after that. I believe I managed to get the one of the transceivers to work with the router, but I did not get the transceiver to work with the ISP. Fiber is an extremely complicated topic, I really don’t understand much about so I just opted to pay.
