I am trying to attach a HFS+ formatted, USB drive. This is somewhat related to my other posting: Mount read-write HFS+ drive in OpenWRT.
I installed the necessary packages: hfsfsck
, kmod-fs-hfs
, kmod-fs-hfsplus
, mkhfs
, and sshfs
I created a mounting directory: /mnt/jetdrive
I added a dummy file to the directory to make it easy to determine if the drive is actually mounted:
# ls -al /mnt/jetdrive
drwxr-xr-x 1 root root 48 Sep 10 18:50 .
drwxr-xr-x 1 root root 58 Sep 10 18:50 ..
-rw-r--r-- 1 root root 0 Sep 10 18:49 jetdrive not mounted.txt
Got the device specifics:
# lsblk -f
sdc
|-sdc1 vfat EFI 67E3-XXXX
`-sdc2 hfsplus JetDrive 500GB dfeb02d3-XXXX-XXXX-XXXX-54d540ac16eb
For some reason, the hfsplus
partition’s UUID isn’t included in the UI’s list, but the vfat
partition is:
I used the custom option to add the hfsplus
partition’s UUID, which resulted in the fstab
file:
config mount
option enabled '1'
option target '/mnt/jetdrive'
option fstype 'hfsplus'
option options 'force,rw'
option enabled_fsck '1'
option uuid 'dfeb02d3-XXXX-XXXX-XXXX-54d540ac16eb'
The UI thinks that the device isn’t presented:
Which is supported by listing the directory:
# ls -al /mnt/jetdrive/
If I mount the device using /dev/sdc2
config mount
option enabled '1'
option device '/dev/sdc2'
the mount is successful:
# ll jetdrive/
-rw-r--r-- 1 99 99 6148 Aug 13 2017 .DS_Store
dr-xr-xr-t 1 root root 2 Jun 29 2017 .HFS+ Private Directory Data?/
drwx------ 1 99 99 5 Jun 29 2017 .Spotlight-V100/
drwx------ 1 99 99 5 Sep 10 18:39 .fseventsd/
---------- 1 root root 41943040 Jun 29 2017 .journal
---------- 1 root root 4096 Jun 29 2017 .journal_info_block
Questions:
- Can
hfsplus
devices be mounted using the UUID? - Does it matter if I use the front or rear USB port? Does this result in a different
/dev
listing?
Ultimately, I would like to make /mnt/jetdrive
read-only if the device doesn’t mount successfully (to prevent damage to the flash memory), but read-write if it is successful. Can this be done?
