if I have such a problem in Windows desktop, I look in the browser in the revision of the element and I can find in its code where the advertisement refers to. I add this address to the AdBlock blacklist. But I only use YouTube on desktop. How to get to the mobile version I have no idea
?? www.youtube.com/?app=mobile ??
Otherwise, as I am logged in to Youtube, I don’t have any ads.
AdBlock configuration
Status / Version enabled / 4.1.3
Blocked Domains 51 168
Active Sources adaway, adguard, android_tracking, reg_cz
DNS Backend kresd (-), /etc/kresd
Run Utils download: /usr/libexec/wget-ssl, sort: /usr/libexec/sort-coreutils, awk: /bin/busybox
Run Interfaces trigger: wan, report: br-lan
Run Directories base: /tmp, backup: /srv/adblock, report: /srv/adblock, jail: /tmp
Run Flags backup: ✔, flush: ✔, force: ✔, search: ✘, report: ✔, mail: ✘, jail: ✘
User Blacklist
doubleclick.net
cat.fr.eu.criteo.com
cat.nl.eu.criteo.com
clicktrack.pubmatic.com
content.aimatch.com
criteo.net
pagead2.googlesyndication.com
pix.eu.criteo.net
s0.2mdn.net
static.criteo.net
Pokud odkazy reklamy jsou na doménu Youtube jako u Seznamu, pak asi řešení není
