my Omnia router is not booting, booting from usb rescue while serial is connected results in this:
Searching for medkit
[ 9.831442] scsi 0:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 9.839973] sd 0:0:0:0: [sda] 131072000 512-byte logical blocks: (67.1 GB/62.5 GiB)
[ 9.847761] sd 0:0:0:0: [sda] Write Protect is off
[ 9.852683] sd 0:0:0:0: [sda] No Caching mode page found
[ 9.858008] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 9.915222] sda: sda1
[ 9.918235] sd 0:0:0:0: [sda] Attached SCSI removable disk
mount: mounting /dev/mmcblk1p1 on /mnt/src failed: No such device or address
mount: mounting /dev/sda on /mnt/src failed: Invalid argument
[ 10.155746] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Trying device /dev/sda1
ls: medkit-omnia.tar.gz: No such file or directory
ls: medkit-omnia-*.tar.gz: No such file or directory
Found omnia-medkit-latest.tar.gz on device /dev/sda1
Nothing wrong with it
1
And its our newest one!
[ 10.846381] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Repartitioning the drive...
Debug info:
fdisk: can't open '/dev/mmcblk0'
Partitioning drive failed
it seems as though the system doesn’t see the emmc device, is the emmc dead?
can you break the bootloader and send us the result of command mmc info and mmc part please?
Like this…
U-Boot 2021.10-rc3-00044-gbc930e94463f (Sep 08 2021 - 12:35:49 +0200)
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 1 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Disabling MCU watchdog... disabled
WDT: Started with servicing (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPIFlash... SF: Detected s25fl164k with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: Turris Omnia
Turris Omnia:
RAM size: 1024 MiB
Serial Number: 0000000ABCDEFEDC
Regdomain set to **
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000
Hit any key to stop autoboot: 0
=> mmc info
Device: mv_sdh
Manufacturer ID: 90
OEM: 14a
Bus Speed: 52000000
Mode: MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 4 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
=> mmc part
Partition Map for MMC device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 16 15269872 263fdf1c-01 83
