Ipv6: wan6 ok, lan stopped
need help with my Turris Omnia ipv6 configuration.
Last week, my devices stopped working over ipv6 (i think after an ISP-Modem or TO update).
I resetted modem and TO, configured, rolled back, nothing helped.
No device behind TO gets an public ipv6 address. TO wan6 seems ok, ping6 ipv6.google.com works fine.
Combinations:
  • Works: Modem <> Devices
  • Works: Modem <> AVM Repeater <> Devices
  • Fails: Modem <> TO <> Devices
_
ifconfig output:
eth2
Link encap:Ethernet HWaddr D8:58:D7:XX:XX:XX
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2a02:8388:701:b980:xxxx:xxxx:xxxx:xxxx/64 Scope:Global
inet6 addr: fe80::da58:d7ff:fe00:3bda/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:24311 errors:0 dropped:0 overruns:0 frame:0
TX packets:23199 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:9314532 (8.8 MiB) TX bytes:5208100 (4.9 MiB)
Interrupt:39
br-lan
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fdc9:69:69:1::1/64 Scope:Global
inet6 addr: fe80::da58:d7ff:fe00:3bd9/64 Scope:Link
RX packets:734 errors:0 dropped:0 overruns:0 frame:0
TX packets:347 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:44382 (43.3 KiB) TX bytes:120607 (117.7 KiB)
ifstatus wan6:
“up”: true,
“pending”: false,
“available”: true,
“autostart”: true,
“dynamic”: false,
“uptime”: 95,
“l3_device”: “eth2”,
“proto”: “dhcpv6”,
“device”: “eth2”,
“metric”: 0,
“dns_metric”: 0,
“delegation”: true,
“ipv4-address”: [
    "ipv6-address": [
                    "address": "2a02:8388:701:b980:xxxx:xxxx:xxxx:xxxx",
                    "mask": 64,
                    "preferred": 604797,
                    "valid": 1209597
    "ipv6-prefix": [
    "ipv6-prefix-assignment": [
    "route": [
                    "target": "2a02:8388:701:b980::",
                    "mask": 64,
                    "nexthop": "::",
                    "metric": 256,
                    "valid": 1209597,
                    "source": "::/0"
                    "mask": 57,
                    "nexthop": "fe80::aef8:ccff:fe1e:3985",
                    "metric": 512,
                    "valid": 1209597,
                    "source": "2a02:8388:701:b980:xxxx:xxxx:xxxx:xxxx/64"
                    "target": "::",
                    "mask": 0,
                    "metric": 512,
                    "valid": 1797,
    "dns-server": [
            "2a02:8383:d:c::1",
            "2a02:8383:d:c::1000"
    "dns-search": [
    "neighbors": [
    "inactive": {
            "ipv4-address": [
            "ipv6-address": [
            "route": [
            "dns-server": [
            "dns-search": [
            "neighbors": [
    "data": {
            "passthru": "001700202a028383000d000c00000000000000012a028383000d000c0000000000001000"
ifstatus lan:
“up”: true,
“pending”: false,
“available”: true,
“autostart”: true,
“dynamic”: false,
“uptime”: 161,
“l3_device”: “br-lan”,
“proto”: “static”,
“device”: “br-lan”,
“updated”: [
“addresses”
“metric”: 0,
“dns_metric”: 0,
“delegation”: true,
“ipv4-address”: [
“address”: “192.168.1.1”,
“mask”: 24
“ipv6-address”: [
    "ipv6-prefix": [
                    "address": "fdc9:69:69:1::",
                    "mask": 64,
                    "local-address": {
                            "address": "fdc9:69:69:1::1",
                            "mask": 64
    "route": [
    "dns-server": [
    "dns-search": [
    "neighbors": [
    "inactive": {
            "ipv4-address": [
            "ipv6-address": [
            "route": [
            "dns-server": [
            "dns-search": [
            "neighbors": [
    "data": {
uci show network:
network.loopback=interface
network.loopback.ifname=‘lo’
network.loopback.proto=‘static’
network.loopback.ipaddr=‘127.0.0.1’
network.loopback.netmask=‘255.0.0.0’
network.globals=globals
network.globals.ula_prefix=‘fdc9:69:69::/48’
network.lan=interface
network.lan.type=‘bridge’
network.lan.proto=‘static’
network.lan.ipaddr=‘192.168.1.1’
network.lan.netmask=‘255.255.255.0’
network.lan.bridge_empty=‘1’
network.lan.ifname=‘lan0’ ‘lan1’ ‘lan2’ ‘lan3’ ‘lan4’
network.lan._turris_mode=‘managed’
network.lan.ip6assign=‘64’
network.wan=interface
network.wan.ifname=‘eth2’
network.wan.proto=‘static’
network.wan.netmask=‘255.255.255.0’
network.wan.gateway=‘192.168.0.1’
network.wan.ipaddr=‘192.168.0.2’
network.wan.ipv6=‘1’
network.wan.dns=‘1.1.1.1’ ‘9.9.9.9’
network.guest_turris=interface
network.guest_turris.type=‘bridge’
network.guest_turris.proto=‘static’
network.guest_turris.ipaddr=‘10.111.222.1’
network.guest_turris.netmask=‘255.255.255.0’
network.guest_turris.bridge_empty=‘1’
network.guest_turris.dns=‘192.168.1.4’
network.guest_turris.enabled=‘0’
network.guest_turris.ip6assign=‘64’
network.wan6=interface
network.wan6.ifname=‘@wan
network.wan6.proto=‘dhcpv6’
network.wan6.reqprefix=‘auto’
network.wan6.reqaddress=‘try’
network.vpn_turris=interface
network.vpn_turris.enabled=‘1’
network.vpn_turris.ifname=‘tun_turris’
network.vpn_turris.proto=‘none’
network.vpn_turris.auto=‘1’
Other infos:
ISP:
magenta.at (cable)
DS-Lite
Modem DHCPv6 server:
Any solutions?
Thanks in advance
Since this is obviously DOCSIS, blame the cable modem. Most of them are super crappy and either don’t do DHCPv6-PD at all or can delegate only to one device. If it worked before, try doing a factory reset of the cable modem. Hopefully it will be able to delegate the one prefix again.
What is the size of the prefix delegated to you with DHCPv6-PD? In case it is /64 only, you can try to enable the NDP proxy on your Turris Omnia.
I have no idea, I configured ipv6 manually before that happened.
I’ll keep trying.
Thanks
Added / Changed these lines and now it works again.
/etc/config/dhcp:
config dhcp ‘lan’
option dhcpv6 ‘relay’
option ra ‘relay’
option ndp ‘relay’
config dhcp ‘wan6’
option ra ‘relay’
option ndp ‘relay’
option master ‘1’
option interface ‘wan6’
https://openwrt.org/docs/guide-user/network/ipv6/configuration#ipv6_relay
Screenshots
Screenshot_20220302_131005
