Hello!
I have an IPv6 /60 subnet assigned from my provider and at some point in the past the Omnia assigned addresses to my LAN devices as well. I’m not sure what happened (at least a few reboots) but that’s not working anymore.
ifstatus wan6
is reporting:
{ "up": true, "pending": false, "available": true, "autostart": true, "dynamic": false, "uptime": 221186, "l3_device": "eth1", "proto": "dhcpv6", "device": "eth1", "metric": 0, "delegation": false, "ipv4-address": [ ], "ipv6-address": [ { "address": "xxxx:xxxx:xxxx:xxxx:35aa:13c4:59ae:9657", "mask": 128, "preferred": 215779, "valid": 215779 } ], "ipv6-prefix": [ { "address": "xxxx:xxxx:xxxx:9b80::", "mask": 60, "preferred": 215779, "valid": 215779, "class": "wan6", "assigned": { } } ], "ipv6-prefix-assignment": [ ], "route": [ { "target": "::", "mask": 0, "nexthop": "fe80::1a8b:9dff:fed4:2022", "metric": 512, "valid": 1798, "source": "xxxx:xxxx:xxxx:9b80::\/60" }, { "target": "::", "mask": 0, "nexthop": "fe80::1a8b:9dff:fed4:2022", "metric": 512, "valid": 1798, "source": "xxxx:xxxx:xxxx:xxxx:35aa:13c4:59ae:9657\/128" } ], "dns-server": [ "2001:558:feed::1", "2001:558:feed::2" ], "dns-search": [ ], "inactive": { "ipv4-address": [ ], "ipv6-address": [ ], "route": [ ], "dns-server": [ ], "dns-search": [ ] }, "data": { "passthru": "xxxx" } }
It looks like there is a /60 subnet available but it’s not being assigned to the LAN (none of the LAN hosts are receiving an IPv6 address in that subnet).
ifstatus lan
says:
{ "up": true, "pending": false, "available": true, "autostart": true, "dynamic": false, "uptime": 221557, "l3_device": "br-lan", "proto": "static", "device": "br-lan", "updated": [ "addresses" ], "metric": 0, "delegation": true, "ipv4-address": [ { "address": "10.1.0.1", "mask": 24 } ], "ipv6-address": [ ], "ipv6-prefix": [ ], "ipv6-prefix-assignment": [ { "address": "fd20:4a9d:8566:1::", "mask": 64 } ], "route": [ ], "dns-server": [ ], "dns-search": [ ], "inactive": { "ipv4-address": [ ], "ipv6-address": [ ], "route": [ ], "dns-server": [ ], "dns-search": [ ] }, "data": { } }
Any ideas? Internal IPv6 works fine, it seems to work fine from the router itself as well. All relevant settings seem OK:
config interface 'lan' option ifname 'eth0 eth2' option force_link '1' option type 'bridge' option proto 'static' option netmask '255.255.255.0' option ipaddr '10.1.0.1' option ip6assign '64'
