There is a lot of stuff in there but nothing that gives me a clue that the system tried to set this route.
For example I find this traceback:
2016-12-26T18:40:57+01:00 debug updater[2712]: src/lib/locks.c:44 (lua_acquire): Trying to get a lock at //var/lock/opkg.lock
2016-12-26T18:40:57+01:00 debug updater[2712]: backend.lua:347 (status_parse): Parsing status file /usr/lib/opkg/status
2016-12-26T18:40:57+01:00 debug updater[2712]: src/lib/journal.c:123 (journal_open): Opening journal
2016-12-26T18:40:57+01:00 emerg sfpswitch.py[1599]: line not found
2016-12-26T18:40:57+01:00 debug updater[2712]: src/lib/interpreter.c:105 (interpreter_error_result): ^M
Stack Traceback
(2) Lua function ‘?’ at line 64 of chunk ‘“logging”]’^M
Local variables:^M
err = string: “[string “transaction”]:351: No journal to recover”^M
err2string = Lua function ‘?’ (defined at line 45 of chunk “logging”])^M
msg = string: “
(*temporary) = table: 0x7ff670 {msg:
[string “transaction”]:351: No journal to recover}^M
(3) C function ‘function: 0x69c970’^M
(4) field C function ‘recover’^M
(5) Lua global ‘recover’ at line 351 of chunk ‘“transaction”]’^M
Local variables:^M
run_state = table: 0x6b46f0 {initialized:true, init:function: 0x6b4720, lfile:userdata: 0x6ce348, release:function: 0x687340 (more…)}^M
(6) Lua function ‘?’ at line 412 of chunk ‘“transaction”]’^M
Local variables:^M
(*temporary) = Lua function ‘?’ (defined at line 378 of chunk “transaction”])^M
2016-12-26T18:40:57+01:00 crit updater[2712]: src/opkg-trans/main.c:102 (main):
2016-12-26T18:40:57+01:00 emerg sfpswitch.py[1599]: ^[[31;1mDIE^[[0m:
2016-12-26T18:40:57+01:00 emerg sfpswitch.py[1599]: [string “transaction”]:351: No journal to recover
2016-12-26T18:40:57+01:00 emerg sfpswitch.py[1599]: Aborted
