I know, that there where similar posts, but none fully covered my case. I do have prefix and I’m getting IPv6 address on local clients, but there is not possible to ping router address (RA) from LAN, however it is work from router directly, so I guess I miss some small thing, but I can’t figure out, what.
ifstatus wan6
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"uptime": 8510,
"l3_device": "eth2",
"proto": "dhcpv6",
"device": "eth2",
"metric": 0,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"ipv6-address": [
"address": "2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:ad3",
"mask": 64
"address": "2a00:ca8:a1f:6076::5",
"mask": 128
"ipv6-prefix": [
"address": "2a00:ca8:a1f:6076::",
"mask": 64,
"class": "wan6",
"assigned": {
"lan": {
"mask": 64
"ipv6-prefix-assignment": [
"route": [
"target": "2a00:ca8:a1f:6076::",
"mask": 64,
"nexthop": "::",
"metric": 256,
"source": "::\/0"
"target": "::",
"mask": 0,
"nexthop": "fe80::4682:e5ff:fe76:9b5a",
"metric": 512,
"valid": 1791,
"source": "2a00:ca8:a1f:6076::\/64"
"target": "::",
"mask": 0,
"metric": 512,
"valid": 1791,
"source": "2a00:ca8:a1f:xxxx:xxxx:xxxx:xxxx:ad3\/64"
"target": "::",
"mask": 0,
"metric": 512,
"valid": 1791,
"source": "2a00:ca8:xxx:xxxx::5\/128"
"dns-server": [
"2a00:ca8::100",
"2a00:ca8:0:1::20"
"dns-search": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"data": {
"passthru": "xxxxx....xxxxx"
LAN conf:
ifstatus lan
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"uptime": 991,
"l3_device": "br-lan",
"proto": "static",
"device": "br-lan",
"updated": [
"addresses"
"metric": 0,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"address": "192.168.1.1",
"mask": 24
"ipv6-address": [
"ipv6-prefix": [
"address": "2a00:ca8:xxx:xxxx::",
"mask": 64,
"local-address": {
"address": "2a00:ca8:xxxx:xxxx::1",
"mask": 64
"route": [
"dns-server": [
"dns-search": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"data": {
Routes, network on client
ping6 google.com
PING6(56=40+8+8 bytes) 2a00:ca8:xxxx:xxxx:xxxxx:xxxxx:f9e4:d90 --> 2a00:1450:4014:80c::200e
^C
--- google.com ping6 statistics ---
4 packets transmitted, 0 packets received, 100.0% packet loss
IPs
# ifconfig en0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 8c:85:90:35:75:e9
inet6 fe80::106d:xxxx:xxxxx:d7ad%en0 prefixlen 64 secured scopeid 0x8
inet 192.168.1.106 netmask 0xffffff00 broadcast 192.168.1.255
inet6 2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:73e8 prefixlen 64 autoconf secured
inet6 2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:d90 prefixlen 64 autoconf temporary
inet6 2a00:ca8:a1f:6076::xxxx prefixlen 64 dynamic
nd6 options=201<PERFORMNUD,DAD>
media: autoselect
status: active
Routing table
# netstat -f inet6 -rn
Routing tables
Internet6:
Destination Gateway Flags Netif Expire
default fe80::da58:d7ff:fe00:ad1%en0 UGc en0
default fe80::%utun0 UGcI utun0
::1 ::1 UHL lo0
2a00:ca8:a1f:6076::/64 link#8 UC en0
2a00:ca8:a1f:6076::1 d8:58:d7:0:a:d1 UHLWIi en0
2a00:ca8:a1f:6076::1a8 0:11:32:74:1a:1b UHLWI en0
2a00:ca8:a1f:6076::ea0 8c:85:90:35:75:e9 UHL lo0
2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:1a1b 0:11:32:74:1a:1b UHLWI en0
2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:73e8 8c:85:90:35:75:e9 UHL lo0
2a00:ca8:a1f:6076:xxxx:xxxx:xxxx:d90 8c:85:90:35:75:e9 UHL lo0
fe80::%lo0/64 fe80::1%lo0 UcI lo0
fe80::1%lo0 link#1 UHLI lo0
fe80::%en0/64 link#8 UCI en0
fe80::106d:1ade:d5e5:d7ad%en0 8c:85:90:35:75:e9 UHLI lo0
fe80::da58:d7ff:fe00:ad1%en0 d8:58:d7:0:a:d1 UHLWIir en0
fe80::%awdl0/64 link#10 UCI awdl0
fe80::4839:cbff:fe79:7e5d%awdl0 4a:39:cb:79:7e:5d UHLI lo0
fe80::%bridge0/64 link#11 UCI bridge0
fe80::8400:64ff:fe4a:ac00%bridge0 86.0.64.4a.ac.0 UHLI lo0
fe80::%utun0/64 fe80::5d25:c3dd:a895:d7af%utun0 UcI utun0
fe80::5d25:c3dd:a895:d7af%utun0 link#12 UHLI lo0
ff01::%lo0/32 ::1 UmCI lo0
ff01::%en0/32 link#8 UmCI en0
ff01::%awdl0/32 link#10 UmCI awdl0
ff01::%bridge0/32 link#11 UmCI bridge0
ff01::%utun0/32 fe80::5d25:c3dd:a895:d7af%utun0 UmCI utun0
ff02::%lo0/32 ::1 UmCI lo0
ff02::%en0/32 link#8 UmCI en0
ff02::%awdl0/32 link#10 UmCI awdl0
ff02::%bridge0/32 link#11 UmCI bridge0
ff02::%utun0/32 fe80::5d25:c3dd:a895:d7af%utun0 UmCI utun0
