I am trying to configure ipv6 again after the reset to factory default. As far as I remember, it was just working out of the box previously, but now I cannot get it to work. Here is the information I find relevant:
- I can ping and trace ipv6 resource both from the router itself and from the device in LAN:
PING google.ru (2a00:1450:4010:c0e::5e): 56 data bytes
64 bytes from 2a00:1450:4010:c0e::5e: seq=0 ttl=51 time=20.579 ms
64 bytes from 2a00:1450:4010:c0e::5e: seq=1 ttl=51 time=20.520 ms
64 bytes from 2a00:1450:4010:c0e::5e: seq=2 ttl=51 time=20.619 ms
- I CANNOT access ipv6 resources via the browser or by curl:
curl -v6 google.com
- Failed to connect to google.com port 80: Host is unreachable
curl: (7) Failed to connect to google.com port 80: Host is unreachable
- Here is /etc/config/network:
config interface ‘wan’
option ifname ‘eth1’
option proto ‘pppoe’
option ipv6 ‘1’
config interface ‘wan6’
option ifname ‘@wan’
option proto ‘dhcpv6’
- For some reason in LuCI wan6 looks like the cable is not connected while IPv6-PD is there:
