Following up to How to add 6in4? → The 6in4 tunnel is working. I can ping from the turris omnia easily:
root@turris:~# ping6 hetzner.de
PING hetzner.de(2a01:4f8:0:5176::3) 56 data bytes
64 bytes from 2a01:4f8:0:5176::3: icmp_seq=1 ttl=56 time=22.0 ms
64 bytes from 2a01:4f8:0:5176::3: icmp_seq=2 ttl=56 time=22.2 ms
64 bytes from 2a01:4f8:0:5176::3: icmp_seq=3 ttl=56 time=22.0 ms
Other lan clients also have ipv6 address now, but whenever I try to ping, I get the error “destination unreachable; port unreachable”
root@servi:~# ping6 hetzner.de
PING hetzner.de (2a01:4f8:0:5176::3): 56 data bytes
64 bytes from 2001:470:26:1b4::1: Destination unreachable: Port unreachable
This happens on linux clients as well as windows clients.
config interface 'wan6in4'
option proto '6in4'
option mtu '1480'
option 'peeraddr' '216.66.80.98'
option 'ip6addr' '2001:470:25:xxx::2/64'
option 'ip6prefix' '2001:470:26:xxx::/64'
# The following parameters are only necessary if Turris has a dynamic IPv4 address
option 'tunnelid' 'xxx'
option 'username' 'xxx'
option 'password' 'xxx'
/etc/config/firewall
config rule
option name 'wan6in4'
option family 'ipv4'
option src 'wan'
option src_ip '216.66.80.98' #Server IPv4 address
option proto '41'
option target 'ACCEPT'
