Was anyone able to configure iptables nflog with ulogd?
#plugin="/usr/lib/ulogd/ulogd_inppkt_NFLOG.so"
#plugin="/usr/lib/ulogd/ulogd_inppkt_ULOG.so"
#plugin="/usr/lib/ulogd/ulogd_inppkt_UNIXSOCK.so"
#plugin="/usr/lib/ulogd/ulogd_inpflow_NFCT.so"
#plugin="/usr/lib/ulogd/ulogd_filter_IFINDEX.so"
#plugin="/usr/lib/ulogd/ulogd_filter_IP2STR.so"
#plugin="/usr/lib/ulogd/ulogd_filter_IP2BIN.so"
#plugin="/usr/lib/ulogd/ulogd_filter_IP2HBIN.so"
#plugin="/usr/lib/ulogd/ulogd_filter_PRINTPKT.so"
#plugin="/usr/lib/ulogd/ulogd_filter_HWHDR.so"
#plugin="/usr/lib/ulogd/ulogd_filter_PRINTFLOW.so"
#plugin="/usr/lib/ulogd/ulogd_filter_MARK.so"
#plugin="/usr/lib/ulogd/ulogd_output_LOGEMU.so"
#plugin="/usr/lib/ulogd/ulogd_output_SYSLOG.so"
#plugin="/usr/lib/ulogd/ulogd_output_XML.so"
#plugin="/usr/lib/ulogd/ulogd_output_SQLITE3.so"
#plugin="/usr/lib/ulogd/ulogd_output_GPRINT.so"
#plugin="/usr/lib/ulogd/ulogd_output_NACCT.so"
#plugin="/usr/lib/ulogd/ulogd_output_PCAP.so"
#plugin="/usr/lib/ulogd/ulogd_output_PGSQL.so"
#plugin="/usr/lib/ulogd/ulogd_output_MYSQL.so"
#plugin="/usr/lib/ulogd/ulogd_output_DBI.so"
#plugin="/usr/lib/ulogd/ulogd_raw2packet_BASE.so"
#plugin="/usr/lib/ulogd/ulogd_inpflow_NFACCT.so"
#plugin="/usr/lib/ulogd/ulogd_output_GRAPHITE.so"
#plugin="/usr/lib/ulogd/ulogd_output_JSON.so"
these are listed libs in ulogd cfg but only ulogd_raw2packet_BASE exists by ulogd installation.
Is there a way to get these libs? Or at least is there some ulogd plugin package to install?
Many thanks.
