I’d like to report a serious bug/wifi problem. I keep getting disconnected from the wifi on my iPhone during FaceTime calls. It was quite suspicious for a while and I was finally able to confirm this is something the Turris Omnia Wifi card is responsible for.
I’d appreciate any ideas on how to perform more detailed diagnostics.
See the following kernel log:
[16586449.087998] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510] (irq=POLL)
[16586449.098066] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[16586449.801832] br-guest_turris: port 3(wlan1) entered blocking state
[16586449.808265] br-guest_turris: port 3(wlan1) entered disabled state
[16586449.814911] device wlan1 entered promiscuous mode
[16586449.820017] br-guest_turris: port 3(wlan1) entered blocking state
[16586449.826393] br-guest_turris: port 3(wlan1) entered forwarding state
[16586449.833149] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest_turris: link becomes ready
[16586449.918782] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[16586450.189752] mv88e6085 f1072004.mdio-mii:10 lan4: Link is Up - 100Mbps/Full - flow control off
[16586451.181670] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control off
[16586451.338715] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
[16586451.360434] br-guest_turris: port 2(lan4) entered blocking state
[16586451.366745] br-guest_turris: port 2(lan4) entered forwarding state
[16586451.373289] IPv6: ADDRCONF(NETDEV_CHANGE): lan0: link becomes ready
[16586451.380300] br-lan: port 1(lan0.10) entered blocking state
[16586451.386068] br-lan: port 1(lan0.10) entered forwarding state
[16586451.392147] br-guest_turris: port 1(lan0.20) entered blocking state
[16586451.398707] br-guest_turris: port 1(lan0.20) entered forwarding state
[16586451.406971] br-lan: port 4(wlan0) entered blocking state
[16586451.412598] br-lan: port 4(wlan0) entered disabled state
[16586451.418351] device wlan0 entered promiscuous mode
[16586451.427195] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[16586451.876627] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[16586451.883595] br-lan: port 4(wlan0) entered blocking state
[16586451.889223] br-lan: port 4(wlan0) entered forwarding state
[16586451.978773] br-lan: port 5(wlan0-1) entered blocking state
[16586451.984740] br-lan: port 5(wlan0-1) entered disabled state
[16586451.990732] device wlan0-1 entered promiscuous mode
[16586452.024475] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control off
[16586452.069172] IPv6: ADDRCONF(NETDEV_CHANGE): lan3: link becomes ready
[16586452.105624] br-lan: port 5(wlan0-1) entered blocking state
[16586452.111453] br-lan: port 5(wlan0-1) entered forwarding state
[16586452.267181] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[16586452.275416] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[16586452.379068] br-lan: port 5(wlan0-1) entered disabled state
[16586452.442260] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
[16586452.449287] br-lan: port 5(wlan0-1) entered blocking state
[16586452.455059] br-lan: port 5(wlan0-1) entered forwarding state
