Confirming the option, Save & Apply in Luci Rainbow … turns off the LEDs and the LED intensity must be adjusted with the HW button or the rainbow brightness
command
Confirmation of the option, Save & Apply in Luci LED Configuration, does not perform the set action in the parameter Link on / not enabled
if it is not changed (parameter must be enabled-save and disabled-save again).
The command in the terminal rainbow brightness -p 10
works but setting the LED brightness size in cron with /etc/cron.d/leds control
does not work
00 07 * * * /usr/bin/rainbow brightness -p 10
00 08 * * * * /usr/bin/rainbow brightness -p 16
00 09 * * * * /usr/bin/rainbow brightness -p 30
00 16 * * * * /usr/bin/rainbow brightness -p 16
00 17 * * * * /usr/bin/rainbow brightness -p 10
00 18 * * * * /usr/bin/rainbow brightness -p 5
*/3 * * * * root /root/connCheck.sh
The instruction called in this file does not work either for check internet connection
The same instruction rainbow brightness
in Terminal or Custom Commands responds adequately
