I am using igmpproxy for tvheadend running on one of my server in my network, to connect to multicast streams provided by my ISP.
Up to a few days ago, it was working fine. I could watch streams from tvheadend or from VLC running on another computer (not at the same time though).
Since a few days, it does not work anymore. Basically, it works, I can switch from one stream to another without any problem. Then if I stop playing, I cannot reconnect ever to any stream on subsequent play. Only solution is to stop igmpproxy, let it stopped for a few seconds and restart it. Only then the first client will be able to reconnect to a multicast stream and switch channel until it disconnects.
My configuration is the following and hast not changed:
config igmpproxy
option quickleave 1
option verbose 1 #(none, minimal[default], more, maximum)
config phyint
option network wan
option zone wan
option direction upstream
list altnet 0.0.0.0/0
config phyint
option network lan
option zone lan
option direction downstream
Any idea what could be the issue?
