after yesterday forced Factory reset I have a problem with 5GHz WiFi. This card isn’t loading anymore. Any idea?
dmesg:
[ 16.881842] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 16.887719] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 17.063275] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[ 17.074015] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 17.083722] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 17.092841] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[ 17.103239] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 17.112687] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 17.129601] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 17.138874] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 17.148402] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[ 17.193132] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[ 17.200241] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[ 17.210718] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 17.220279] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[ 17.230198] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 18.359053] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 18.451027] ath: EEPROM regdomain: 0x0
[ 18.451032] ath: EEPROM indicates default country code should be used
[ 18.451034] ath: doing EEPROM country->regdmn map search
[ 18.451039] ath: country maps to regdmn code: 0x3a
[ 18.451042] ath: Country alpha2 being used: US
[ 18.451044] ath: Regpair used: 0x3a
log:
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): nl80211: Could not configure driver mode
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): nl80211: deinit ifname=wlan0 disabled_11b_rates=0
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): nl80211 driver initialization failed.
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): wlan0: interface state UNINITIALIZED->DISABLED
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): wlan0: AP-DISABLED
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): wlan0: CTRL-EVENT-TERMINATING
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): hostapd_free_hapd_data: Interface wlan0 wasn’t started
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): cat: can’t open ‘/var/run/wifi-phy0.pid’: No such file or directory
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): Command failed: Invalid argument
2018-01-27T09:39:12+01:00 notice netifd[]: radio0 (20280): Device setup failed: HOSTAPD_START_FAILED
