I am trying to set up a DNS tunnel with iodined (0.7.0) and the current (5.2.3 - HBK) version of TurrisOS and I systematically fail. For now I want the server to work before I go into the client.
What I tried:
I’ve setup my domain stuff:
t.mydomain.tld NS ns.mydomain.tld
ns.mydomain.tld A $MY_PUBLIC_ROUTER_IP
I also forwarded ports because of running kresd and I runned iodine like that:
/etc/config/firewall:
config redirect
option src ‘wan’
option name ‘DNS Tunnel’
option src_dport ‘53’
option target ‘DNAT’
option dest_ip ‘$MY_LOCAL_ROUTER_IP’
option dest ‘lan’
option src_dip ‘$MY_PUBLIC_ROUTER_IP’
option dest_port ‘153’
list proto ‘udp’
root@router:~# LC_ALL=C iodined -f -DD -u nobody -d dns0 -m 1500 -l $MY_LOCAL_ROUTER_IP -p 153 -P testpassword 10.222.111.254/28 t.mydomain.tld
ALERT! Other dns servers expect you to run on port 53.
You must manually forward port 53 to port 153 for things to work.
Debug level 2 enabled, will stay in foreground.
Add more -D switches to set higher debug level.
Opened dns0
Setting IP of dns0 to 10.222.111.254
Setting MTU of dns0 to 1500
Opened IPv4 UDP socket
Limiting to 13 simultaneous users because of netmask /28
Listening to dns for domain t.mydomain.tld
But whenever I try to test the setup with: https://code.kryo.se/iodine/check-it/
it fails:
Troubleshoot your iodine setup
Analyzing DNS setup for tunnel domain ‘t.mydomain.tld’… (might take some time)
Looking for nameserver for mydomain.tld… got ns3.afraid.org (at 67.220.81.190).
Resolving delegation of t.mydomain.tld at 67.220.81.190… to ns.mydomain.tld (at $MY_PUBLIC_ROUTER_IP).Expecting iodined to be accessible at $MY_PUBLIC_ROUTER_IP… no reply.
Error: Make sure iodined is running and the firewall accepts UDP port 53. Also check any port forwards in use.
EDIT (some more info):
root@router:~# netstat -tulpn | grep 53
tcp 0 0 0.0.0.0:853 0.0.0.0:* LISTEN 19807/kresd
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 19807/kresd
tcp 0 0 :::53 :::* LISTEN 19807/kresd
tcp 0 0 :::853 :::* LISTEN 19807/kresd
udp 0 0 $MY_LOCAL_ROUTER_IP:5353 0.0.0.0:* 10949/python3
udp 0 0 10.111.222.254:5353 0.0.0.0:* 10949/python3
udp 0 0 $MY_PUBLIC_ROUTER_IP:5353 0.0.0.0:* 10949/python3
udp 0 0 127.0.0.1:5353 0.0.0.0:* 10949/python3
udp 0 0 10.111.111.1:5353 0.0.0.0:* 10949/python3
udp 0 0 0.0.0.0:5353 0.0.0.0:* 10949/python3
udp 0 0 224.0.0.251:5353 0.0.0.0:* 11204/umdns
udp 0 0 $MY_LOCAL_ROUTER_IP:5353 0.0.0.0:* 11204/umdns
udp 0 0 0.0.0.0:53 0.0.0.0:* 19807/kresd
udp 0 0 $MY_LOCAL_ROUTER_IP:153 0.0.0.0:* 24249/iodined
udp 0 0 ff02::fb:5353 :::* 11204/umdns
udp 0 0 fe80::da58:d7ff:fe00:20ac:5353 :::* 11204/umdns
udp 0 0 :::53 :::* 19807/kresd
Also sudo nmap
(from the world) mydomain.tld -Pn -sU -p 53
gives:
Starting Nmap 7.80 ( https://nmap.org ) at 2021-07-02 16:12 CEST
Nmap scan report for mydomain.tld ($MY_PUBLIC_ROUTER_IP)
Host is up.PORT STATE SERVICE
53/udp open|filtered domainNmap done: 1 IP address (1 host up) scanned in 11.37 seconds
Anybody tried something similar? How does it comply with Turris honeypots enabled?
Thanks,
AreYouLoco?
