I want to setup my Mox to extend the WLAN Range of my Omnia. I have no Ethernet cable between Mox and Omnia location:
Internet --- | Turris |----<WiFi>----| Turris |
| Omnia | | Mox |
| +--<WiFi>-- Clients +--<WiFi>-- Clients
+--<Ethernet>-- Clients
I found a tutorial in the OpenWrt Docs , but I cannot get things running. It only works with Ethernet Connection between Omnia and Mox.
Has anyone working tutorial for that or useful hints?
omnia wifi has option wds ‘1’ set for channel 1
mox /etc/config/wireless is:
config wifi-device 'radio0'
option type 'mac80211'
option channel '36'
option hwmode '11a'
option macaddr '...'
option htmode 'VHT80'
option disabled '0'
option country 'DE'
option legacy_rates '1'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'mox-ssid'
option disabled '0'
option encryption 'psk2+ccmp'
option wpa_group_rekey '86400'
option key '-..-'
config wifi-device 'radio1'
option disabled '0'
option channel '1'
option hwmode '11g'
option country 'DE'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'sta'
option ssid 'omina-ssid'
option disabled '0'
option key '...'
config wifi-iface 'guest_iface_0'
option disabled '1'
config wifi-iface 'guest_iface_1'
option disabled '1'
Hi Jack,
I tried it from the same page You mentioned.
Can You see if there is a bug in my configuration, or send my your /etc/config/wireless ?
ATM my Mox does not connect to the Omnia via WiFi.
Hi Milaber,
I configured my equipement via Luci GUI. Reading/editting the config files is not for me.
As soon as I have acces to my equipement (later today) I will post my config files so you can have a look at them.
BTW: My set-up is slightly different
ISP (Modem) — TO (Router-AP) ---- Netgear R7800 (AP) — wds— Archer C7
I dont allow wifi clients on the Archer only ethernet connections.
The wds link on the Archer is made by the 2.4 GHz, the 5 Ghz is disabled. I guess enabling the 5 GHz would allow wifi clients (did not try this).
Here are mine config files. Hope they help you.
R7800
etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fde7:85e4:91e8::/48'
config interface 'lan'
option type 'bridge'
option ifname 'eth1.1'
option ip6assign '60'
option ipaddr '192.168.1.2'
option gateway '192.168.1.1'
option dns '192.168.1.1'
config interface 'wan'
option ifname 'eth0.2'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 2 3 4 6t'
config switch_vlan
option vlan '2'
option ports '5 0t'
etc/config/wireless
option hwmode '11a'
option path 'soc/1b500000.pci/pci0000:00/0000:00:00.0/0000:01:00.0'
option country 'US'
option channel '40'
option mode 'ap'
option ssid 'SkyNet node 5'
option key '************'
option wpa_disable_eapol_key_retries '1'
option wps_pushbutton '0'
option channel '11'
option hwmode '11g'
option path 'soc/1b700000.pci/pci0001:00/0001:00:00.0/0001:01:00.0'
option htmode 'HT20'
option country 'US'
option mode 'ap'
option wds '1'
option ssid 'SkyNet node 24'
option key '****************'
ArcherC7
etc/config/network
option ifname 'lo'
option ula_prefix 'fd66:9404:04b6::/48'
option ipaddr '192.168.1.3'
option ifname 'eth0.1'
option proto 'dhcp'
option auto '0'
option auto '0'
config switch
option reset '1'
config switch_vlan
option vlan '1'
option ports '2 3 4 5 0t'
config switch_vlan
option vlan '2'
option ports '1 0t'
etc/config/wireless
option hwmode '11a'
option path 'pci0000:00/0000:00:00.0'
option channel '40'
option legacy_rates '0'
option country 'US'
option mode 'ap'
option key '**************'
option disabled '1'
option channel '11'
option hwmode '11g'
option path 'platform/qca956x_wmac'
option disabled '0'
option country 'US'
config wifi-iface
option encryption 'psk2'
option mode 'sta'
option bssid '**:**:**:**:**:**'
option wds '1'
thx jack,
i’ll be back home on friday - will check then …
Perry
July 15, 2019, 9:51pm
7
Just another guide: https://doc.turris.cz/doc/en/public/repeater . I haven’t tried, but I want to.
