Hi, I want to use ipsets in mwan3 config but dnsmasq used in turris omnis is not compiled with support of ipsets.
How can I do it?
Thanks for help
How can I do it?
Thanks for help
Are you using dnsmasq or dnsmasq-full?
My understand is that standard dnsmasq doesn’t support ipsets. Therefore, you’ll need to uninstall it and install dnsmasq-full instead.
