Is it possible to fork a thread?
Anyway, I used the recommended test at Speed test - how fast is your internet? | DSLReports, ISP Information
Here are the results. You can clearly see the 4 times where I disabled SQM (the first one, the last one and two in the middle to verify that the line is still Ok).
After enabling SQM again with the above mentioned settings I get attached output of the commands you mention.
Peter
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"uptime": 1587452,
"l3_device": "eth0",
"proto": "dhcp",
"device": "eth0",
"metric": 0,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"address": "192.168.2.100",
"mask": 24
"ipv6-address": [
"ipv6-prefix": [
"ipv6-prefix-assignment": [
"route": [
"target": "0.0.0.0",
"mask": 0,
"nexthop": "192.168.2.1",
"source": "192.168.2.100/32"
"dns-server": [
"192.168.2.1"
"dns-search": [
"speedport.ip"
"neighbors": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"neighbors": [
"data": {
"leasetime": 1814400
config queue 'eth1'
option interface 'eth1'
option qdisc_advanced '0'
option debug_logging '0'
option verbosity '5'
option qdisc 'cake'
option script 'piece_of_cake.qos'
option linklayer 'atm'
option overhead '44'
option enabled '1'
option download '45000'
option upload '10000'
qdisc noqueue 0: dev lo root refcnt 2
qdisc mq 0: dev eth0 root
qdisc fq_codel 0: dev eth0 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc cake 8035: dev eth1 root refcnt 9 bandwidth 10Mbit besteffort triple-isolate nonat nowash no-ack-filter split-gso rtt 100.0ms atm overhead 44
qdisc ingress ffff: dev eth1 parent ffff:fff1 ----------------
qdisc noqueue 0: dev lan1 root refcnt 2
qdisc noqueue 0: dev lan2 root refcnt 2
qdisc noqueue 0: dev lan3 root refcnt 2
qdisc noqueue 0: dev lan4 root refcnt 2
qdisc noqueue 0: dev lan5 root refcnt 2
qdisc noqueue 0: dev lan6 root refcnt 2
qdisc noqueue 0: dev lan7 root refcnt 2
qdisc noqueue 0: dev lan8 root refcnt 2
qdisc noqueue 0: dev lan9 root refcnt 2
qdisc noqueue 0: dev lan10 root refcnt 2
qdisc noqueue 0: dev lan11 root refcnt 2
qdisc noqueue 0: dev lan12 root refcnt 2
qdisc noqueue 0: dev lan13 root refcnt 2
qdisc noqueue 0: dev lan14 root refcnt 2
qdisc noqueue 0: dev lan15 root refcnt 2
qdisc noqueue 0: dev lan16 root refcnt 2
qdisc noqueue 0: dev br-guest root refcnt 2
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc noqueue 0: dev br-office root refcnt 2
qdisc noqueue 0: dev br-printer root refcnt 2
qdisc noqueue 0: dev br-testing root refcnt 2
qdisc noqueue 0: dev br-wlan root refcnt 2
qdisc cake 8036: dev ifb4eth1 root refcnt 2 bandwidth 45Mbit besteffort triple-isolate nonat wash no-ack-filter split-gso rtt 100.0ms atm overhead 44
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
Sent 13985429198 bytes 72307043 pkt (dropped 0, overlimits 0 requeues 1)
backlog 0b 0p requeues 1
maxpacket 0 drop_overlimit 0 new_flow_count 0 ecn_mark 0
new_flows_len 0 old_flows_len 0
maxpacket 1466 drop_overlimit 0 new_flow_count 652 ecn_mark 0
Sent 100177517 bytes 73927 pkt (dropped 3467, overlimits 214537 requeues 0)
memory used: 792Kb of 4Mb
capacity estimate: 10Mbit
min/max network layer size: 28 / 1500
min/max overhead-adjusted size: 106 / 1749
average network hdr offset: 18
Tin 0
thresh 10Mbit
target 5.0ms
interval 100.0ms
pk_delay 7.5ms
av_delay 4.6ms
sp_delay 14us
backlog 0b
pkts 77394
bytes 105078902
way_inds 96
way_miss 262
way_cols 0
drops 3467
marks 0
ack_drop 0
sp_flows 2
bk_flows 1
un_flows 0
max_len 7590
quantum 305
Sent 4355258 bytes 32876 pkt (dropped 0, overlimits 0 requeues 0)
Sent 4813064 bytes 32874 pkt (dropped 2, overlimits 6791 requeues 0)
memory used: 96768b of 4Mb
capacity estimate: 45Mbit
min/max network layer size: 50 / 1456
min/max overhead-adjusted size: 106 / 1696
average network hdr offset: 14
Tin 0
thresh 45Mbit
target 5.0ms
interval 100.0ms
pk_delay 314us
av_delay 24us
sp_delay 9us
backlog 0b
pkts 32876
bytes 4815522
way_inds 0
way_miss 1
way_cols 0
drops 2
marks 0
ack_drop 0
sp_flows 0
bk_flows 1
un_flows 0
max_len 1470
quantum 1373
