Is there any solution for this USB issue?
I have Turris Omnia and both USBs are unstable and HDDs disconnects after some time. I encounter this issue in the past and then my turris have one year pause in the paper box (due to house reconstruction) but it didn’t grow up. Possible HW issue?
What is package for usbreset? It seems I don’t have it included.
Thanks
Attaching some logs…
[ 6187.010995] xhci-hcd f10f0000.usb3: xHCI host not responding to stop endpoint command.
[ 6187.011006] xhci-hcd f10f0000.usb3: Assuming host is dying, halting host.
[ 6187.011024] xhci-hcd f10f0000.usb3: HC died; cleaning up
[ 6187.016545] usb 3-1: USB disconnect, device number 2
[ 6187.031033] sd 2:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 6187.031045] sd 2:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 ff 0d d8 00 00 1e 00
[ 6187.031050] blk_update_request: I/O error, dev sda, sector 536374976
[ 6187.037467] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67047174)
[ 6187.037473] Buffer I/O error on device sda2, logical block 66970112
[ 6187.043759] Buffer I/O error on device sda2, logical block 66970113
[ 6187.050040] Buffer I/O error on device sda2, logical block 66970114
[ 6187.056321] Buffer I/O error on device sda2, logical block 66970115
[ 6187.062601] Buffer I/O error on device sda2, logical block 66970116
[ 6187.068882] Buffer I/O error on device sda2, logical block 66970117
[ 6187.075162] Buffer I/O error on device sda2, logical block 66970118
[ 6187.081442] Buffer I/O error on device sda2, logical block 66970119
[ 6187.087723] Buffer I/O error on device sda2, logical block 66970120
[ 6187.094003] Buffer I/O error on device sda2, logical block 66970121
[ 6187.100581] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67047430)
[ 6187.100869] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67047686)
[ 6187.101181] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67047942)
[ 6187.101485] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67048198)
[ 6187.101773] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 587202560 size 8388608 starting block 67048454)
[ 6187.102056] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 595591168 size 5767168 starting block 67048710)
[ 6187.102338] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 595591168 size 5767168 starting block 67048966)
[ 6187.102620] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 595591168 size 5767168 starting block 67049222)
[ 6187.102903] EXT4-fs warning (device sda2): ext4_end_bio:330: I/O error -5 writing to inode 98697877 (offset 595591168 size 5767168 starting block 67049478)
[ 6187.111027] sd 2:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 6187.111038] sd 2:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 ff 0d f6 00 00 10 00
[ 6187.111044] blk_update_request: I/O error, dev sda, sector 536375216
[ 6187.187990] JBD2: Detected IO errors while flushing file data on sda2-8
[ 6187.188017] Aborting journal on device sda2-8.
[ 6187.192533] JBD2: Error -5 detected when updating journal superblock for sda2-8.
[ 6187.200662] JBD2: Detected IO errors while flushing file data on sda2-8
[ 6187.261096] EXT4-fs error (device sda2): ext4_journal_check_start:56: Detected aborted journal
[ 6187.269840] EXT4-fs (sda2): Remounting filesystem read-only
[ 6187.275477] EXT4-fs (sda2): previous I/O error to superblock detected
[ 6187.547456] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6187.547660] sd 2:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 7265.991102] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7266.411050] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7267.241053] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7267.401106] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7267.561041] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7267.721045] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7267.881081] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.041039] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.201035] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.361046] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.521053] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.681039] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7268.841038] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.001040] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.161036] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.321051] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.481045] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.641084] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.801059] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7269.961052] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7270.121058] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7270.281048] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7270.441043] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 7270.601055] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7270.811025] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7271.020999] usb 5-1: device not accepting address 2, error -22
[ 7271.441044] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7271.651019] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7271.860999] usb 5-1: device not accepting address 2, error -22
[ 7272.281040] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7272.491014] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7272.700993] usb 5-1: device not accepting address 2, error -22
[ 7273.121046] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7273.331077] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 7273.540994] usb 5-1: device not accepting address 2, error -22
[ 7273.601030] usb 5-1: USB disconnect, device number 2
[ 7273.621036] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 7273.621046] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 17 51 2c 9a 00 00 1e 00
[ 7273.621052] blk_update_request: I/O error, dev sda, sector 3129566416
[ 7273.627518] Buffer I/O error on dev sda2, logical block 391118996, lost async page write
[ 7273.635650] Buffer I/O error on dev sda2, logical block 391118997, lost async page write
[ 7273.643769] Buffer I/O error on dev sda2, logical block 391118998, lost async page write
[ 7273.651886] Buffer I/O error on dev sda2, logical block 391118999, lost async page write
[ 7273.659997] Buffer I/O error on dev sda2, logical block 391119000, lost async page write
[ 7273.668113] Buffer I/O error on dev sda2, logical block 391119001, lost async page write
[ 7273.676228] Buffer I/O error on dev sda2, logical block 391119002, lost async page write
[ 7273.684343] Buffer I/O error on dev sda2, logical block 391119003, lost async page write
[ 7273.692458] Buffer I/O error on dev sda2, logical block 391119004, lost async page write
[ 7273.700571] Buffer I/O error on dev sda2, logical block 391119005, lost async page write
[ 7273.713162] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 7273.713172] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 17 51 2c b8 00 00 1e 00
[ 7273.713177] blk_update_request: I/O error, dev sda, sector 3129566656
[ 7273.719725] blk_update_request: I/O error, dev sda, sector 0
[ 7273.725430] JBD2: recovery failed
[ 7273.725438] EXT4-fs (sda2): error loading journal
[ 7273.749470] blk_update_request: I/O error, dev sda, sector 0
[ 7273.755172] JBD2: recovery failed
[ 7273.755179] EXT4-fs (sda2): error loading journal
[ 7273.773510] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 7273.773626] sd 3:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 7273.776370] VFS: Dirty inode writeback failed for block device sda2 (err=-5).
[ 7288.268462] xhci-hcd f10f8000.usb3: Stopped the command ring failed, maybe the host is dead
[ 7288.276840] xhci-hcd f10f8000.usb3: Abort command ring failed
[ 7288.282782] xhci-hcd f10f8000.usb3: HC died; cleaning up
[ 7288.288125] xhci-hcd f10f8000.usb3: Error while assigning device slot ID
[ 7288.294961] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.294971] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.294979] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.294985] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.294997] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.295004] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.295010] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.295017] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.295023] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.295032] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[ 7288.296427] xhci-hcd f10f8000.usb3: Max number of devices this xHCI host supports is 32.
[ 7288.305590] usb usb5-port1: couldn't allocate usb_device
