How to reinit reForis "New devices detection (Experimental)"?
Title says it all. There clearly is a persistent database. Where is it?
Depends where you set it to be. Its a simple SQLITE database. Take a look in /etc/config/dev-detect config file. You may delete the database and restart service or fiddle with the database using some sqlite tool or use:
dev-detect clear
