I get IP, but I have not access to Foris or LuCi. I only get access by SSH but I do not know the default password…
I have tried rename omnia-medkit-latest-minimal.tar.gz to omnia-medkit-latest.tar.gz without luck.
— EDITED —
I’ve left the router are-flashing again and I’ve go to smoke a cigar, when I’ve back everything was equal. I’ve unplug the USB, plug it on PC to put omnia-medkit-latest-full.tar.gz and when I’ve plug it again, in router, the leds have flashing in green and now I have access…
But with this error:
Firmware update has failed due to a connection or installation error. You should check your cable connection before proceeding to the next step. But do not worry much about the update as the router will run the updater regularly.
# cat /etc/config/updater
config pkglists 'pkglists'
list lists 'base'
list lists 'cacerts'
list lists 'luci-controls'
list lists 'lxc'
list lists 'nas'
list lists 'netutils'
list lists 'shell-utils'
config override 'override'
option disable '0'
root@turris:~# updater.sh
WARN:Multiple candidates from same repository with same version for package shairport-sync-openssl
WARN:Couldn’t load flags: cannot open /usr/share/updater/flags: No such file or directory
INFO:Queue install of kmod-usb-serial/turris/4.4.35+15-1-34abcd5e548fc8ed5390269f3a31d173-15
INFO:Queue install of kmod-usb-serial-wwan/turris/4.4.35+15-1-34abcd5e548fc8ed5390269f3a31d173-15
INFO:Queue install of kmod-usb-serial-qualcomm/turris/4.4.35+15-1-34abcd5e548fc8ed5390269f3a31d173-15
INFO:Executing preupdate hooks…
INFO:Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:
Snapshot number 1 created
INFO:End of subprogram output
INFO:Executing postupdate hooks…
uci: Entry not found
And after do full power cycle (reboot do that disappear my wifi 5GHz) all seems work without troubles.
PS: If omnia-medkit-latest-minimal has marked packages groups as “nas” they will by installed in the start wizard, in step “update”, and “minimal” will not be “minimal”.
The same for Turris 1.0 - I had to use medkit from SD card and got the same error and had also bad URLs … “turris-stable-new” … after change to “turris” - all OK
