How to log in to LXC debian jessie container
I finally installed my Turris Omnia and am playing around a bit.
Via the luci admin interface I managed to create and start an LXC container running debian jessie. Now it is unclear to me how to access that container.
root@turris:~# lxc-console -n debian
Connected to tty 1
Type <Ctrl+a q> to exit the console, <Ctrl+a Ctrl+a> to enter Ctrl+a itself
Debian GNU/Linux 8 LXC_NAME tty1
LXC_NAME login:
Which login / password to use to access this container that (according to the luci interface) was created from the standard image at api.turris.cz/lxc?
i think you have to first use lxc-attach <container-name> , that gives you direct shell (if as root, you will be logged as root directly), so later you can make all the normal stuff with new debian passwd,sudoers, new users…etc…) …, once finished with basic setup, you can use lxc-console.
Yes, that works. Thanks a lot.
