Hello folks,
I would like to create a second wifi network so I can test a Hobby project that im working on. The devices are connected via wifi but the connection to the internet is causing me some problems. I would like to create a second wifi network that has no connection to the internet. How do I do that?
Many thanks
In LuCi - Network - Interfaces click [Add new Interface]
Give a name to the interface, Protocol:Static address, select the WiFi you created earlier, click submit.
In the next screen,
- General Setup:
- set a IP address (if you are already using 192.168.100.1 set something like 192.168.200.1 netmask 255.255.255.0)
- set a Gateway (same as in above step)
- DHCP Server: Create a DHCP Server
- Firewall Settings: create a new Firewall zone: name
click [save and Apply]
In Network - Firewall edit the new zone,
General Setting: maybe allow forwarding to and from LAN but not WAN depending on what you want to achieve.
Traffic Rules: add two new forward rules:
name-dns rule [Add and Edit] Source zone: (the one you created), Destination: Device, Destination port: 53 [save and Apply]
name-dhcp rule [Add and Edit] Source zone: (the one you created), Source port: 67-68, Destination: Device, Destination port: 67-68 [save and Apply]
I created a IOT-devices network this way, but allowed only to WAN and not to LAN in the General Settings of the Firewall.
