How to configure TeamSpeak or uMurmur
I’d like to set up teamspeak3 or uMurmur on turris omnia for myself. Has anyone tried this before and could point me to an installation guide? I’m lost. Here’s what I tried:
TeamSpeak
I’ve tried to do it locally on my machine but I need to map port to let people in. Not sure if that’s a good idea. I’ve tried to open port 9987, 30033 and 10011 in the firewall but with no success.
There’s a TeamSpeak2 package available for turris but I could manage to find how to configure it.
uMurmur
There’s a package available and a bit more documentation available but I couldn’t say if the server was up nor make the client connect. Also, I couldn’t find how to let other people connect to my server.
first are you talking about TS3 and then about TS2.
So if we’re talking about TS3 (and should be also for TS2) there is no planned ARM port for TS3 server.
I dont know, but you can try to use ExaGear (which I didnt try it on router, yet.)
What should work is Mumble (which is open source) and has arm port, but I didn’t try it either.
Exagear+teamspeak3 server is running fine, I’ve just installed it to my debian lxc container.
You just need to buy exagear for armv7 and follow the setup.
root@LXC_NAME:~# arch
armv7l
root@LXC_NAME:~# exagear
Starting /bin/bash in the guest image /opt/exagear/images/debian-8
i686
