How can I properly configure and enable 802.11w for my wireless interface.
I tried adding ieee80211w option under /etc/config/wireless, I cannot verify if everything is configured properly.
Also if this configuration is even supported on Omnia or not?
I didn’t find straightforward method for validation, but it seems that Turris works well with the 802.11w.
Here are my investigation results:
it seems that clients as well AP wifi hardware/OS needs to support the 802.11w
by setting
uci commit wireless
wifi```
- X=2 - limited number of my devices could connect and operate
- X=1 - all devices worked
* my investigation based:
- https://wiki.openwrt.org/doc/uci/wireless
- http://www.mikealbano.com/2016/02/what-do-your-wifi-clients-support.html (with examples sub-link)
Note: I did the tests using 2,4/5G default Turris' card in 2,4 n-mode with WPA2 802.1X (CCMP).
